02-22-2016, 05:44 PM | #1 |
12 volt ignition
Have a 47 Ford thats been converted to 12 volt. It has an electronic dist. I have a 47 dist. with an earlier cap (crab style). Which distributor condenser should i use and which coil Thanks
02-22-2016, 06:31 PM | #2 |
Re: 12 volt ignition
Am I reading your post correctly:
You have an electronic dist. And, you also have a 47 dist with a crab style cap. Now, which distributor (if you in dead have two) are you asking the condenser/coil question about? Or is the 47 distributor converted to an electronic pickup? |
02-22-2016, 09:27 PM | #3 |
Sorry for not being clear. I want to replace the electronic distributor with a points distributor for better advance. it is a 47 distributor with a crab type cap. I need to know what to run as a condenser and what type 12 volt coil to use . Thanks
02-22-2016, 09:52 PM | #4 |
Good discussion to have with Bubba. I understand points uses a different coil. My '47 has a fine-running electronic using crab style distributor. No problems with ignition advance. Bubba made a complete spare set-up for me.
02-22-2016, 10:06 PM | #5 | |
Without the ballast resistor the best coil is the Bosh Blue coil which is about a 4.0 ohm coil. With a ballast resistor you need a 1.5 to 2.0 ohms coil with the ballast resistor making up the difference (an additional 1.5 to 2.0 ohms) for somewhere around 3.5 to 4.0 ohms total resistance in the circuit. |
02-22-2016, 10:09 PM | #6 |
http://www.bubbasignition.com/condensors.html Also thread on similar subject: https://fordbarn.com/forum/showthread...ght=bosch+coil And: http://www.ratwell.com/technical/BlueCoil.html Last edited by JSeery; 02-22-2016 at 10:27 PM. |
02-22-2016, 10:42 PM | #7 |
There would be no difference in the advance UNLESS it was a different brand name etc. The Ford crabs all have the same advance ( 11A assembly) ,if its a Mallory , pro comp or MSD thats a different story , but easily fixed with a tear down and adjust.....
Some more info: http://www.bubbasignition.com/crab-42-48.html |
