Old 11-13-2018, 01:16 AM   #1
Lawrie
Lawrie's Avatar
Default oil lines
Any one know where to get the 3/8 steel tees that some folks use in the lifter galery to route the oil lines to the mains
I just spent hours on the new to no avail
Lawrie
Lawrie is offline   Reply With Quote
Old 11-13-2018, 07:14 AM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: oil lines
Aviation supply vendors is where I have seen them. If you cannot find them, consider making them.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 11-13-2018, 10:02 AM   #3
katy
katy's Avatar
Something like this?
https://www.fairviewfittings.com/Ind...ter-91230.html
Old 11-13-2018, 12:28 PM   #4
Jim Brierley
I just use sweat-on copper fittings.
Jim Brierley is offline   Reply With Quote
Old 11-13-2018, 04:40 PM   #5
Lawrie
Lawrie's Avatar
Jim, I wanted to use steel ones,not copper.I ,m worried about vibration work hardening the copper.
Katy, I want weld in ones not the hydraulic type,
Brent, I will look at an aviation supply co.
Thanks Lawrie
Old 11-13-2018, 04:51 PM   #6
txkhog
McMaster Carr has socket weld tee fittings in SS
txkhog is offline   Reply With Quote
Old 11-14-2018, 12:41 PM   #7
Jim Brierley
Lawrie, long copper lines will crack from vibration but not short, rigid ones or long ones if supported to eliminate movement. I don't think you would have any trouble at all with tees. Many older cars had a small, long copper line to the oil pressure gauge but I never saw one break, doesn't mean they never did, I just never saw a broken one.
Old 11-14-2018, 03:54 PM   #8
Lawrie
Lawrie's Avatar
Jim, I will look at the copper ones,
But I have an engine in my shop that has a nice pressure feed setup to the mains and it has the steel tees,I cant ask the owner as he didnt build the engine.
Lawrie
Old 11-14-2018, 07:04 PM   #9
AL in NY
AL in NY's Avatar
Swagelok makes all kinds of SS fittings. There should be a local distributor near you.
https://www.swagelok.com/en/catalog/Fittings?gclid=EAIaIQobChMI6JqBlozV3gIVhZ-zCh3FaAv_EAMYASAAEgJv2fD_BwE
AL in NY
AL in NY is offline   Reply With Quote
Old 11-14-2018, 07:18 PM   #10
Lawrie
Lawrie's Avatar
Swagloc are the screw together type,I need the socket weld fittings,
there will be no room for a screw together fitting.
thanks Lawrie
Old 11-19-2018, 01:06 PM   #11
Jim Brierley
Lawrie, If your steel lines will fit snugly into copper tees, you should be able to sweat them together, copper and steel are both compatible with solder.
Old 11-19-2018, 04:36 PM   #12
Lawrie
Lawrie's Avatar
Jim
I have had a closer look at the tees in the engine,it looks like they are home made,
I have done up a dummy oil line in steel tube and will make my own tees from steel and silver solder them to the 3/8tube.
Will post some pics when done.
thanks Lawrie
Old 11-19-2018, 08:50 PM   #13
Brian in Wheeling
Brian in Wheeling's Avatar
Yea, Lawrie that should work just fine.
Brian
Brian in Wheeling is offline   Reply With Quote
