Old 05-15-2021, 11:09 AM   #1
46woodie
Default Passenger window metal rail
When installing the glass in rear doors I found the riser arms popping out of the metal channel on the bottom of glass. Can I just get a wood block and tap this metal channel about 1" left or right OR is there another/correct way to move this without breaking glass. Thanks
46woodie is offline   Reply With Quote
Old 05-15-2021, 12:07 PM   #2
TJ
TJ's Avatar
Default Re: Passenger window metal rail
You could tap it left or right, but keep in mind that the glass channel setting tape may not move with the channel.
Old 05-15-2021, 12:19 PM   #3
46woodie
Thanks, I had the same concern. May just wait till Mond and let glass co. that cut my glass reinstall the piece.
