Old 09-28-2023, 07:15 AM   #1
John R
Default Red Primer Paint
I was planning to use a primer in the red oxide color because that color was used originally by Ford in 1932. Paint supplier here says its not available anymore - apparently discontinued a year or two ago. Is it really gone?
Those who do not move do not die, but are they not already dead?
John R is offline   Reply With Quote
Old 09-28-2023, 07:22 AM   #2
alanwoodieman
Default Re: Red Primer Paint
use two stage epoxy primer and add a little red tint
Old 09-28-2023, 09:53 AM   #3
OldGold360
Southern Polyurethanes has an epoxy primer available in various colors including red oxide. I have not used their epoxy primer before but a painter friend has and said it is a great product. It is made in the USA.
OldGold360 is offline   Reply With Quote
Old 09-28-2023, 10:34 AM   #4
ssffnomad
ssffnomad's Avatar
SPI - Southern Polyurethane epoxy is excellent.
Perfect for underside of a 55-57 C . . . rolet
ssffnomad is offline   Reply With Quote
Old 09-28-2023, 05:54 PM   #5
fordv8j
fordv8j's Avatar
Red rustrolium primer..at hardware store
fordv8j is offline   Reply With Quote
Old 09-28-2023, 07:25 PM   #6
DavidG
DavidG's Avatar
Your starting point, what was used originally on '32s isn't actually consistent with the available archival evidence.
Old 09-28-2023, 10:08 PM   #7
John R
David, not sure I understand your point. When I first stripped my Tudor in 1964 or so, it had red oxide colored primer that was a bit hard to remove by chemical stripping. I assumed it was original, maybe I was mistaken. So, if not red, what was used at the factory?
Thanks.
Old 09-28-2023, 07:58 PM   #8
52flthed
Didn't they use Red or Gray primer?
52flthed is offline   Reply With Quote
Old 09-28-2023, 10:26 PM   #9
DavidG
DavidG's Avatar
Some red, but mostly dark gray on the thirty plus or so that I have had.
Old 09-28-2023, 10:29 PM   #10
John R
Thanks. I'll relax my search for red!
Old 09-29-2023, 04:11 AM   #11
flathead48
SPI Has a great red oxide epoxy primer, have used it for about 5 years without a problem
flathead48 is offline   Reply With Quote
