Old 12-03-2015, 02:05 PM   #21
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Default Re: elelmentary question: how do you best drain the gas tank
Originally Posted by Tom Wesenberg View Post
I do it the same as Mitch said.
You can buy a 10 foot length of clear tubing at Menards for only a couple bucks. This is also handy to use as a syphon hose because you can see exactly where the gas is and stop sucking before you swallow any gas. When I use the tubing to syphon, I slip it over a foot of metal tubing, so it stick straight into the tank and stays on the bottom.
Tom,
A friend caught a guy coughing & wheezing as if he might DIE & the siphon hose was just laying there, running the gas down the DRIVEWAY! Friend was tempted to have the guy BREATH OUT, while he struck a MATCH
Bill W.
"THE ASSISTANT GURU OF STUFF"
