Old 04-07-2021, 11:43 PM   #1
Fred A
Fred A's Avatar
Default '40 Steering Lock Disassembly Follow Up?
Eight years ago Ken/Alabama posted disassembly instructions for the '40. Now having failed to remove the bolt a few times two things are yet to be tried. On instruction 3, is it a must to remove the switch plate? I've been holding off on that trying to preserve the original plate. Secondly, what's holding the bolt from sliding inward as stated in instruction 6.? There is a pressed in pin visible from the back that I suspect. Any thoughts? Thanks Fred A
Fred A is online now   Reply With Quote
Old 04-08-2021, 12:00 AM   #2
cas3
Default Re: '40 Steering Lock Disassembly Follow Up?
grab that pin with your favorite sharp vice grips, and tap the jaw with a hammer to pull it out
Old 04-08-2021, 03:37 AM   #3
Ken/Alabama
Ken/Alabama's Avatar
Did you remove the chrome cap on the end shown in picture #6 ? I disassembled that one without removing the on/off plate.
Old 04-08-2021, 08:36 AM   #4
Terry,OH
Terry,OH's Avatar
The internal steering shaft removed from the column?
Old 04-08-2021, 10:14 AM   #5
G32
Guys; Two different column lockbolt designs!
The switch pin should removed from the earlier model columns
where the pin is staked into the lock bolt (this early designs moving the
the thumb pad rotates the bolt thus the switch pin moves the swiitch
contact).This design the switch pin must be pulled to move the bolt.
About 37 ? the design changed to a nonrotating lockbolt .
The switch pin on these is part of the floating toggle ring assembly
with the thumbpad spline out the top and switch pin on bottom to
the switch contact .Do not take this factory 3 part switch ring
assemby apart. It lifts out of the column drop window (whole) when
the lockbolt is pushed into the drop mast tube space.
Hope this helps .Pictures are someplace.
Please don't take those floating ring assemblys apart.
Not needed
Good old FORD fun!!
Gene Tulsa
G32 is offline   Reply With Quote
Old 04-08-2021, 10:54 AM   #6
Fred A
Fred A's Avatar
My head is spinning with the terminology of the parts. Gene is covering the full '32 to '47 range while I'm focused on the '40. Ken mentioned the cap and it is removed. One candidate lock is off of the mast (tube) and the cap is off but if I don't figure it out otherwise may carefully mask the switch plate and put it together after a careful lube. I have other units in various states of disassembly. Other partsers were dissected with the aid of a hacksaw, in an effort to understand. Hard way to go. Thanks: Fred A
Old 04-08-2021, 01:05 PM   #7
G32
Fred A;
Your lock bolt has a keyway that runs in a guide pin you spotted. There also
is a block bar across the keyway that blocks the bolt from moving inward till
the guide pin is drilled tapped and pulled. The pin and keyway is much smaller
than the pin you see from the bottom.
Looks like Ken was able to disassemble with out pulling the guidepin.
The key cylinder must be removed to slide the lockbolt inward
Good luck Gene Tulsa
Do a search in tis foreum for others opinions - lots:
column lock switch
Old 04-08-2021, 03:28 PM   #8
Ken/Alabama
You are correct. I didn’t remove the guide pin. I’ve disassembled a few 40 lock assemblies and a couple 39 Zephyr lock assemblies and never removed the guide pin. I’ve been asked to repost the instructions I posted years ago so here they are.
File Type: jpg B1474273-247D-4EDD-99CF-1AD0DAA6B742.jpg (50.7 KB, 78 views)
Old 04-08-2021, 03:32 PM   #9
Ken/Alabama
Do a search for 1940 steering lock disassembly. I’m not having any luck trying to post a link to take you there.
Old 04-09-2021, 06:00 AM   #10
glennpm
glennpm's Avatar
Here's the link to Ken's instructions:
https://www.fordbarn.com/forum/showp...13&postcount=1
Glenn
Old 04-09-2021, 12:16 PM   #11
glennpm
glennpm's Avatar
Attached has instructions and pictures in one file. Thank you Ken!
File Type: pdf 1940 Steering lock Disassembly - The Ford Barn W Pics.pdf (434.5 KB, 33 views)
Old 04-09-2021, 06:01 PM   #12
woodiedude
woodiedude's Avatar
Thank you so much for the detailed information as I will be taking my broken lock assembly apart next week
woodiedude is offline   Reply With Quote
Old 04-10-2021, 07:32 AM   #13
FlatHeadCoupe
FlatHeadCoupe's Avatar
If you need replacement parts for any that are not re-usable, I have limited supply in my stash. Also have a couple of 40 column drops already built.
Regards,
FlatHeadCoupe
John McClure
FlatHeadCoupe is offline   Reply With Quote
