12-02-2020, 11:52 AM | #1 |
Oil filter
Hello, I have a 1941 Mercury with the Flathead V8, I cannot find the oil filter. I feel really dumb asking this question, but I can't find it. Was it common in 1941 not to add a filter to the motor?
12-02-2020, 11:56 AM | #2 |
Re: Oil filter
It was common for there not to be an oil filter. If there was one it would be a black canister attached to the head with head bolts. My 41 mercury does not have an oil filter.
12-02-2020, 12:24 PM | #3 |
Re: Oil filter
The filter (proper) looks like this although your '41 had different lines plumbed than the '40.
12-02-2020, 12:25 PM | #4 |
Re: Oil filter
Thank you, I was going crazy trying to find it. I have seen picture of them mounted on the head. I guess mine does not have one. What oil weight do you use since there's no filter?
12-02-2020, 12:27 PM | #5 |
Re: Oil filter
Beautiful Flathead Kube. I definitely do not have that type of filter.
12-02-2020, 12:43 PM | #6 | |
Re: Oil filter
Any good quality name brand oil is way better than what was available in ‘41. I don’t have a filter on my car either. Post a picture of your car when you get a chance. |
12-02-2020, 01:21 PM | #7 | |
Re: Oil filter
I'd suggest you simply change the oil a bit more often than "normal" and forget about installing a filter. Say, every 1000 miles.
12-02-2020, 02:19 PM | #8 |
Re: Oil filter
I'll take a bit of a contrarian view on this, as I believe, given the type of use most of our cars experience, a "bypass filter" can be very beneficial.
If you are not concerned about originality, I would think an 8BA filter canister could be modified for use on an earlier engine. These seem to be fairly easy to find and not that expensive. They resemble the factory setups enough that the casual observer will never know, and they take an easily available element. The mount would have to be fabricated (unless you are lucky enough to find a '49 filter) and some steel lines bent up. You would have to be sure to find one with the junction block that contains the .060" orifice and the sending unit. |
12-02-2020, 03:44 PM | #9 |
Re: Oil filter
Thank you,yeah there is only 41,000 miles on the car and motor. I will just change more often. Thanks again
12-02-2020, 03:44 PM | #10 |
Re: Oil filter
Thank you,yeah there is only 41,000 miles on the car and motor. I will just change it more often. Thanks again
12-02-2020, 03:47 PM | #11 | |
Re: Oil filter
12-02-2020, 06:56 PM | #12 |
Re: Oil filter
It's 20w/50w for me too ! - F F
12-04-2020, 06:12 AM | #13 |
Re: Oil filter
My 41 marks its territory just fine with 20w/50
12-07-2020, 06:54 PM | #14 |
Re: Oil filter
20W50 it is. Thanks
