Old 01-24-2020, 08:51 PM   #1
robert shreveport
Default Not Model A related!
Anyone recommend a epoxy or glue to repair a plastic gas tank? Thanks
robert shreveport is offline   Reply With Quote
Old 01-24-2020, 11:17 PM   #2
Tacoma Bob
Tacoma Bob's Avatar
Default Re: Not Model A related!
I believe JB makes an epoxy for plastics.
Tacoma Bob is offline   Reply With Quote
Old 01-25-2020, 07:38 AM   #3
eagle
eagle's Avatar
I havent had good lock repairing plastic gas tanks with epoxy. The parts houses such as Napa and others have products but for me they didn't last. I have, however, had good results with using donor plastic and a good soldering iron and welding the plastic. Take your time and mix the molten plastic well, especially at the edges, and you can make a nice weld that is strong.
Old 01-25-2020, 09:47 AM   #4
wmws
I have had good luck doing what eagle recommended. On a chain saw it was either weld the plastic or throw the chain saw out as the tank was part of the frame.
wmws is offline   Reply With Quote
Old 01-25-2020, 11:18 AM   #5
robert shreveport
Do y’all use a soldering iron that you heat over a fire or a electric one.
Old 01-26-2020, 08:40 AM   #6
kenparker
kenparker's Avatar
electric one with a heating tip about as big around as your index finger.
kenparker is offline   Reply With Quote
Old 01-26-2020, 09:03 PM   #7
KGBnut
KGBnut's Avatar
Harbor Freight has an inexpensive plastic welder. It is like a soldering iron, but has a nice wide foot. I have had a lot of success with mine.
80 Watt Iron Plastic Welding Kit
Style beats speed any day, and with a lot fewer tickets.
KGBnut is offline   Reply With Quote
