Old 01-02-2021, 04:31 PM   #1
kundun
Default Frame - is it straight?
I inherited a 29 Phaeton which originated from Brazil.
Looking at the car, I assume it had a harsh live and little care.
One of the big things, that bother me is the frame. The car must have had at least one accident as the crossmembers in the front have been reinforced and welded as ugly as possible...
Then, to transport the car in a container away from Brazil the frame was cut in halve and welded together again.
So you might understand that my trust in my frame isnt the best.
I've now found a guy who has frames at sale.
But I need a way to check that the frame that I will buy is as straight as possible. I dont have the tools nor the time to straighten it myself.
Can anybody give a advice or a manual on how to check a frame on its straightness?
And, have there been differences in the frames? Have all models the same frame? Must I only look for a 28/29 frame for me?
thanks a lot,
kundun is offline   Reply With Quote
Old 01-02-2021, 04:51 PM   #2
Synchro909
Synchro909's Avatar
Default Re: Frame - is it straight?
I'm sure someone will post a plan of the chassis with dimensions for you. As for the m all being the same, no they are not. The difference is most obvious at the front cross member. The "pad" on which the radiator sits is lower on the 30/31 chassis than the earlier ones. If you have one of each side by side, you will see what I mean or maybe someone will post a picture of that too.
The most likely place for the chassis to bend is a sag at the rear engine mounts. I clamp a 1/2" thick piece of wood to the rail at the front X member and the other end near the middle X member and stretch a string between them. If there is any sag, it will show as a smaller gap under the string at the engine mounts.
FWIW, The chassis under my Phaeton is bent there and I'm hoping to straighten it without taking everything apart.
With all of that said, I wouldn't trust your welded chassis - replace it. At least a "new" chassis is possible over there.
Old 01-02-2021, 04:52 PM   #3
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Clamp a string onto the front and the back of each frame rail and pull the string taunt. You will see really quickly if it is bent. Also check the measurements diagonally to verify that the measurement is the same in an 'X' pattern.
Plenty of information how to heat shrink a frame back to being straight here in the archives.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 01-02-2021, 04:56 PM   #4
bbrocksr
thanks a lot,
28/29 is different than 30/31 You can check for straightness with a tape measure and a long straight edge or long level [ 8']or a string line.
Bill
bbrocksr is offline   Reply With Quote
Old 01-02-2021, 05:22 PM   #5
Bob Johnson
Bob Johnson's Avatar
Here are a couple of pictures of a bent frame with a string used to show how bent the frame was. The upper picture is the driver side and there is a slight sag around the rear motor mount. The second picture is the passenger side which has a very large bend from the rear motor mount to the front of the car. The frame should be perfectly flat from the back all the way to the front where the front fender support attaches to the frame.
Bob
Bob Johnson is offline   Reply With Quote
Old 01-02-2021, 06:00 PM   #6
kundun
so all 28/29 Modal As have the same frame? no matter of their body style?
Do I understand correct, that the red stings will show me if it is straight on the length (like in Bobs pics) but also not tilting to the left or right.
Brent, how do you do diagonal check? I assume it's hard to check if the left and right is twisted
ps, hope you dont mind me using your pic Brent, was one of the first which popped in the search.
Old 01-02-2021, 06:12 PM   #7
hudson32700
This may be helpful.
hudson32700 is offline   Reply With Quote
Old 01-02-2021, 06:33 PM   #8
Russ/40
Russ/40's Avatar
Although it's implied, it's not specifically stated. The frame needs to be perfectly flat from the front crossmember all the way to the rear crossmember., the full length of the red line on the photo above in post 6.
Old 01-02-2021, 06:41 PM   #9
Jack Shaft
Endeavor to purchase a perfect frame,however its not entirely critical to driveability and in some cases body alignment can correct issues.
Old 01-02-2021, 07:01 PM   #10
David R.
I made some wood blocks and ‘strung’ my AA frame. The rails were level, no sag but about an eight of an inch off side to side. I talked to the owner at a local frame/body shop and he chuckled, said that’s as close as they try to get one they straighten.
David R. is offline   Reply With Quote
Old 01-03-2021, 09:32 AM   #11
BRENT in 10-uh-C
...or it may not. Compared to some factory prints, there are some measurement discrepancies.
BRENT in 10-uh-C
Old 01-03-2021, 01:31 PM   #12
macdonge
macdonge's Avatar
Hudson32700... That's a useful drawing. You wouldn't happen to have a similar one for the 30/31 frame, would you?
macdonge is offline   Reply With Quote
Old 01-03-2021, 06:52 PM   #13
hudson32700
MACDONGE
Go to plucks329s.org for info about mode A frames.
See frame dimensions at: www.wescottauto.com
and click on "tech information".
Old 01-03-2021, 08:05 PM   #14
mike657894
mike657894's Avatar
too add on the string idea.
I use a string tied to two 1 gallon jugs to do my alignments. its a good way to put a straight line in the air next to something
also when im picking out boards. i look down them the long way it becomes easy to see a wow in there.
mike657894 is offline   Reply With Quote
Old 01-03-2021, 09:49 PM   #15
Tim Ayers
Agreed. Quick and dirty way to tell
Old 02-18-2022, 04:00 AM   #16
kundun
reading trough the previous post and for those like me seeking information
the http://www.wescottsauto.com/SubIndexes/Techindex.html has interesting information on it.
there is a detailed explanation about how to frame inspection on straightness
Thanks to Wescotts!
Old 02-18-2022, 08:14 AM   #17
Stretch Cab
Stretch Cab's Avatar
I see this thread is over a year old. Did you ever get a frame? And how about some pictures of your car?
Let us live so that when we come to die, even the undertaker will be sorry. Mark Twain
Stretch Cab is offline   Reply With Quote
Old 02-18-2022, 09:49 AM   #18
BillCNC
BillCNC's Avatar
My frame was bent
When I bought my A, the left fender was lower than the right. I made the mistake in thinking it was the fender bracket, but it was the frame. 1/2" to the right and 1/2" down with the usual sag at the rear motor mounts.
I took measurement from ever single rivet and hole in the frame. The fact that the right side is a mirror image of the left makes measuring simple, but time consuming. I measured every thing in an x pattern starting at the front corner then to every hole and rivet on the opposite side. Once I knew where it was bent, I un riveted the front cross member and I used chains, railroad ties and a porta-power do get the job done right. I got the frame within 1/32" at any point except at the rear motor mound sag area. There I bent it upwards of 1/16" positive. Over time, the known sag area will be perfectly level.
This takes time and patients, and it was well worth it. After the frame was straightened, I took it to get sandblasted, powder coated black, the shot with a couple coats clear of Polyurethane. The spot were the VIN is, has not been powder coated, but has the clear shot over it. The Vin is clearly visible with the appearance of raw metal.
Regards
Bill
BillCNC is offline   Reply With Quote
Old 02-18-2022, 10:24 AM   #19
old ugly
old ugly's Avatar
3 quick checks that you can do
measure corner to corner called cross measuring if its within 1/8-1/4" its ok
lay a straight pipe or 2x4 across the front and one across the rear, then stand at the front or back and sight down it to see if the plane of the 2x4s are parallel, if those lines are parallel then there is no twist.
the third thing is harder but you can run a string along the top of the frame end to end and check for sag.
if those three measurements are good the frame is likely ok.
old posting
but maybe this will help.
old ugly
my old father-in-law told me. "listen close when people tell you how to do stuff they may know something. then do it the way you want."
old ugly is offline   Reply With Quote
