Old 03-06-2024, 01:15 PM   #1
rockfla
rockfla's Avatar
Default What do the experts say?
Got a bone stock 35 21 stud in final assembly stage and want to pole the engine guru's here on the barn as yeah....no, good/bad??
1) Torquing and re-torquing after heat cycles - An old racer/builder here in town told me when re torquing after heat cycling...slightly loosen the head nut and re-torque it each time, don't just throw the torque wrench on it and pull.
2) Stock Aluminum Head - Use copper coat spray or NO??
3) Water Outlet housing, water pumps, timing cover - Use permatex gasket seal on them or NO???
4) Is it best to slightly off set the break on the front seal on the timing cover and oil pan? ALSO should I use a little dab of silicone gasket on the breaks of the seal??
5) What is the torque on the crank pulley bolt?
Thanks in advance and I am sure I will think of one or two more along the way.
Old 03-06-2024, 02:09 PM   #2
Ronnieroadster
Ronnieroadster's Avatar
Default Re: What do the experts say?
Here's how I do it.
1- Never loosen the nut. Check the torque in three steps just as its done at assembly.
2- Yes copper coat
3- A good quality blue, black or gray silicone sealer works perfectly.
4- No need to offset the rope seal at the timing cover however its important you don't shorten the rope seal lengths. Trim the oil pan gasket around the rope seal half's and next use silicone sealer around the outer edges of the rope seal only.
5 - Torque no more than 65 for the crank pulley bolt.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline.
First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH
Ronnieroadster is offline   Reply With Quote
Old 03-06-2024, 02:45 PM   #3
rotorwrench
rotorwrench's Avatar
A person can also use silver spray paint since it has aluminum powder for pigment. Copper coat has copper powder for pigment.
Old 03-06-2024, 02:57 PM   #4
tubman
tubman's Avatar
I agree with this. I am not an "expert" or an "engine guru", but I can read a Galvanic Table.
Old 03-06-2024, 03:30 PM   #5
rockfla
rockfla's Avatar
Well
Sorta a question BUT also from what I remember hearing about stock (Ford) aluminum heads......Isn't max torque on them 45Ft Lbs??? Preferably 40???
Old 03-06-2024, 08:25 PM   #6
pistonbroke
I think Ronnieroadster was referring to your question about the crank pully bolt torque.
pistonbroke is offline   Reply With Quote
Old 03-06-2024, 09:28 PM   #7
Ronnieroadster
That's correct. So the original poster will understand I just added the words crank pulley bolt.
Ronnieroadster
Old 03-07-2024, 07:47 AM   #8
rockfla
rockfla's Avatar
Thank you all, especially RonnieRoadster for sharing your expert knowledge and experience. Sorry for the "misunderstanding" on the torque spec by the way....I was brain locked on the heads for some reason!!
Old 03-07-2024, 08:05 AM   #9
Ol' Ron
Ol' Ron's Avatar
What RR said, saves me from mis spelling som e wods
Gramps
