Old 11-01-2018, 09:04 AM   #21
54vicky
54vicky's Avatar
Default Re: My Rug is Glued Down 50Merc - and needs to come up
the reason I suggested a hair dryer is a heat gun if not careful will melt the carpet.heat gun is useful but I would be leery of using on carpet.hopefully pulling engine without removing carpet works out.
54vicky is offline   Reply With Quote
Old 11-01-2018, 12:00 PM   #22
richard crow
do you have a late 51 with four bolt holding the trans or do you have the earley with the the eight bolts
richard crow is offline   Reply With Quote
Old 11-01-2018, 08:18 PM   #23
Paul Bennett
1950 Merc per avatar donno about nr of bolts ...
however I have located the section of Shop Manual 'Removal of CM Engine'. It provides either removal of transmission through interior (my initial reason for this thread) OR removal with transmission/OD together with engine by removing 2 forward engine mount plus rear OD mounts and disconnect of drive shaft U-bolts.. Later requiring more time.
Paul Bennett is offline   Reply With Quote
Old 11-01-2018, 08:23 PM   #24
Tinker
Tinker's Avatar
I would think the most efficient way to "drop" a transmission is with a lift or jacks. Easier then pulling it through the interior.
"Lot's of ways to skin a cat"... which really sounds like something a psychopath would say.
Old 11-03-2018, 07:56 PM   #25
APDAVE
On My 50 mercury I was able to remove trans and clutch without removing floor mats or pan. Dave
APDAVE is offline   Reply With Quote
