01-13-2022, 12:16 PM | #1 |
Timing
Had lots of cars and only checked the timing on one. How often should you check the timing of a model a.
01-13-2022, 01:06 PM | #2 |
Re: Timing
Not often. It is more important to check the point gap as that will effect the timing and the dwell. Even if you remove the distributor, and do nothing to it, and re install it, you will not have to check the timing. A different distributor or a rebuilt one or new gears for the camshaft or the distributor driving gear or wear over time or a new intermediate shaft would require checking the timing. If you acquire a car then check the timing. I have seen the timing really messed up by someone who adjusted it.
01-13-2022, 03:17 PM | #3 |
Re: Timing
I agree. Not very often. Generally there should be a symptom, i.e. backfire, loss of power, different reaction to timing lever setting, etc. I check points and plugs + or - every 500 miles.
01-13-2022, 04:32 PM | #4 |
Re: Timing
The comment about timing gear ware is important to note. With a new gear and a rebuilt distributor you should be able to go many, many miles without having to change the timing. Low mileage car could go years. We have a car with only 4,000 miles on rebuild, but 20 years. Have changed plugs twice, nothing else. Runs great. If it isn’t broken, don’t try to fix it.
Rotor, points, and plugs are different. Years ago, I had a good friend that owned Model T’s and A’s. He had to mess with the timing on his A’s all the time. He was never happy with how the ran, and they never did run right. Enjoy. |
01-14-2022, 04:08 PM | #5 | |
Re: Timing
01-14-2022, 06:36 PM | #6 | |
Re: Timing
70,000 is a WOW! Great job. Enjoy. |
01-15-2022, 12:39 AM | #7 |
Re: Timing
I never seem to have time to do all I want. I can fill your void!
01-15-2022, 01:17 AM | #8 | |
Re: Timing
The timing lever, on the other hand, needs to be adjusted often for changing conditions-idling, slow speeds, high speeds, hills, even passenger loads. |
01-15-2022, 05:21 AM | #9 | |
Re: Timing
01-15-2022, 09:38 AM | #10 |
Re: Timing
Yes. That's why you regularly check and set the point gap. Of course you can easily compensate for this wear to some extent by moving the timing lever down a couple extra clicks or so. This will get the timing back where it was.
01-15-2022, 11:51 AM | #11 |
Re: Timing
Once you set the point gap and the timing and tightened down the distributor cam you never have to check the timing again unless you fiddle with the distributor cam. (Assuming that you have good teeth on the bottom of the cam that won't slip). If the points close up because of wear on the rubbing block, resetting the gap to the original setting will restore the timing automatically.
