03-08-2018, 02:15 PM | #1 |
Carb question
Hi Guys, My question is can I run 1 carb on my 2 carb std. manifold? I want to test a few 97’s and a few 94’s. and plan to block off the front carb. Will it work?
Regards,Don. |
03-08-2018, 02:51 PM | #2 |
Re: Carb question
First question : is the manifold a regular or a "Super" (one carb over each set of ports)? Probably won't work too well with a "Super" but there are some manifolds I have seen where it might work. The ones I am thinking of have the carbs biased towards the rear of the manifold, so you would be better off blocking off the back carb,
03-08-2018, 04:02 PM | #3 |
Re: Carb question
Hi Tubman, I have a regular manifold and I just blocked off the rear carb. The front carb is right where a stock manifold is. Will try it tomorrow.
Regards, Don |
03-08-2018, 05:36 PM | #4 |
Re: Carb question
That will probably work. Let us know how it turns out. I believe that you can run progressive linkage on those types of manifolds with dual carbs.
03-09-2018, 10:04 AM | #5 |
Re: Carb question
I've done this with many different intakes. AS long as there is a balance tube between the carbs, not a problem. The probably might arise when making WOT Power.
03-09-2018, 11:34 AM | #6 |
Re: Carb question
03-09-2018, 01:22 PM | #7 |
Re: Carb question
I think Ol' Ron means as long as the air path for both carbs are internally connected in the manifold runners, there is no problem.
Sal |
03-09-2018, 07:44 PM | #8 |
Re: Carb question
Cranked it up today and ran fine. Will have to test on the road for power and smooth transition when pulling a load. It idles just fine and seems to have good throttle response.
Regards , Don |
03-10-2018, 12:21 AM | #9 |
Re: Carb question
I have a craving for meatloaf now.
03-10-2018, 09:23 AM | #10 |
Re: Carb question
Many I can get the Bride to make one shaped like a flathead.
Regards, Don |
Thread Tools | |
Display Modes | |
