08-18-2014, 08:55 AM | #1 |
Bell housings.
The green one is for the F-150 3 spd with OD. The Blue one is for the Toyota 5 spd.
08-18-2014, 08:58 AM | #2 |
Re: Bell housings.
So, you're drilling these for adaptors? Looks like your in production mode.
08-18-2014, 09:15 AM | #3 |
Re: Bell housings.
NO, the trans bolts directly to the bell housing for the ford and the Toyota needs a 1/4" spacer. The Toyota bolts to the housing from the inside with 7 bolts we only use 5. No adapters needed.
08-18-2014, 09:32 AM | #4 |
Re: Bell housings.
LOL, I was calling your bell housing modifications an adapter bell housing. What do you call them, just modified bell housings?
08-18-2014, 10:30 AM | #5 |
Re: Bell housings.
These are stock 49/51 Ford bell housings that have been modified to fit the transmission. sometimes this requires some welding and boring the retainer hole larger. Just an inexpensive way to do this. It also allows the use of stock clutch linkage, just find a proper clutch disk for your tranny.
08-18-2014, 12:24 PM | #6 |
Re: Bell housings.
08-18-2014, 01:43 PM | #7 |
Re: Bell housings.
The blue one had a piece welded into the top for the upper bolts, thought that was pretty cool. After welding we refaced the front in a mill.
