12-04-2017, 05:22 PM | #1 |
plug connector fit/length
I notice the fit on the plug connector to spark plugs are not snug? Are there different lengths?
"no one knows more than everyone" |
12-04-2017, 05:28 PM | #2 |
Re: plug connector fit/length
Yes, but repros are different length than originals. Is that what the issue is?
12-04-2017, 05:38 PM | #3 |
12-04-2017, 06:40 PM | #4 |
as per JS-
www.whidbeymodelaclub.com |
12-04-2017, 06:45 PM | #5 |
Here is a pic of my current set up, I have seen other with much more of a bend on its way to the plug?
12-04-2017, 07:24 PM | #6 |
Dave / Lincoln Nebraska |
12-04-2017, 07:31 PM | #7 |
You mean like these, ... New ones from Snyders are the same.
Regards Bill |
12-04-2017, 07:43 PM | #8 |
Mine from Berts are too short also...they barely reach. They're a lot shorter than the setup Brum1 has. I'm using Gambles Tiger take apart plugs.
"That's my wild unsubstantiated guess, and I'm sticking to it regardless of the facts!" |
12-04-2017, 07:49 PM | #9 |
Yes, I have seen a lot of the type that BillCNC is running; would seem to make a better connection; better performance? What does the correct(original) length look like assembled?
12-04-2017, 08:04 PM | #10 |
Besides the right length, the connectors have to be the right material. You want bronze like in post 5 not brass. Bronze is springy for a firmer connection.
12-04-2017, 09:00 PM | #11 |
12-04-2017, 09:02 PM | #12 |
Barb- wire works good too!!! see video above #11
12-05-2017, 09:42 AM | #13 |
When Minervas' distributed body "farted" out sparks to #3, I made a HIGH looped wire, from a single strand of woven clothes line wire & ran it a MONTH, that way! It was FUNNY, the wire was almost INVISABLE!!
Model As ARE SUPPOSED TO BE GREAT FUN FOR IDIOTS LIKE ME---LOL---It's "ALMOST" a substitute for SEX!!! Bill Eccentric
