Old 09-13-2021, 12:35 PM   #1
flathead4rd
flathead4rd's Avatar
Default 50 Ford Crestliner Steering wheel
I need the pad that goes under the steering wheel horn ring. Any suggestions or how to make one? None of the parts suppliers seem to have one for the Crestliner steering wheel.
flathead4rd is offline   Reply With Quote
Old 09-13-2021, 12:43 PM   #2
petehoovie
petehoovie's Avatar
Default Re: 50 Ford Crestliner Steering wheel
Concours Parts & Accessories > https://www.parts123.com/parts123/yb...Z5Z5Z50000051e
3655 Arrowhead Dr - Suite 120
Carson City, NV 89706
800-722-0009
HORN RING INSULATOR
1949-1950
Item# 0A-3672
Catalog
$4.00
Old 09-13-2021, 04:29 PM   #3
mercman from oz
mercman from oz's Avatar
1950 Ford Crestliner Steering Wheel.
Old 09-16-2021, 10:55 AM   #4
flathead4rd
That's the wheel I have but am told the insulator pictured in the post does not work with the Crestliner wheel. Any chance you could remove the horn ring a show a picture of whats underneath? Thanks.
Old 09-17-2021, 10:27 AM   #5
Frank Miller
Frank Miller's Avatar
Try contacting shoebox central in Oklahoma. They will know what you need andmay even have one or a source for it. I know these are reproduced so not sure if individual parts are available.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
Old 09-18-2021, 12:53 PM   #6
ab_36ford
Yep Chris should have em
ab_36ford is offline   Reply With Quote
Old 09-18-2021, 03:54 PM   #7
flathead4rd
Already talked to Chris and he says nobody makes the part for the Crestliner wheel. Just the one for the standard wheel is available.
Old 09-18-2021, 05:40 PM   #8
tubman
tubman's Avatar
There is a persistent rumor that the Ford Crestliners actually used surplus steering wheels sourced from Frazers (look at the stylized "F"). Maybe a check of Kaiser/Frazer parts dealers might turn something up.
Old 09-19-2021, 08:14 AM   #9
Frank Miller
Try here
https://www.hotrodhotline.com/julian...0#.YUc3KH0pDIV
Old 09-19-2021, 08:17 AM   #10
50droptop
This part looks correct to me. Here’s the inside of the accessory wheel, which is the crestliner wheel in a different color.
800-722-0009
HORN RING INSULATOR
1949-1950
Item# 0A-3672
Catalog
$4.00
File Type: jpeg FF855A16-EAC6-47CC-936C-18FF5F5919CA.jpeg (30.7 KB, 26 views)
50droptop is offline   Reply With Quote
Old 09-20-2021, 11:37 AM   #11
JT FORD
JT FORD's Avatar
They are not the same. I have both. They can be made out of weather stripping but it not easy. And if you don't get just right after a while the rubber looses its stength and the horn will hooks til the battery is dead.....
JT FORD is offline   Reply With Quote
Old 09-21-2021, 11:40 AM   #12
flathead4rd
Thanks JT looks like I'll have to make one,
Old 10-01-2021, 01:29 PM   #13
flathead4rd
That does not look like the interior of my steering wheel. Mine has the large nut that holds the wheel to the steering shaft.
