06-22-2020, 09:12 AM | #1 |
Pop Out Switch
If I install a original pop out switch with my new modern set up (no points etc) will it work or should I go with modern ignition switch?
1929 Coupe...... tsk |
06-22-2020, 11:19 AM | #2 |
Re: Pop Out Switch
You got to use a modern switch with modern distributor.
06-22-2020, 01:30 PM | #3 |
Pop Out Switch
Are you sure? I have an original pop out switch installed in my car, and I have a modern distributor still in its shipping box. To me, it looks like modern or old, the distributor would connect the same way. I don’t see how the modern distributor would “know” what kind of switch would be in use. There is only one (armored cable) connection between the pop out switch and the distributor. What am I missing? Sent from my iPhone using Tapatalk |
06-22-2020, 02:34 PM | #4 | |
Re: Pop Out Switch
Which modern distributor do you have? |
06-22-2020, 04:01 PM | #5 |
Re: Pop Out Switch
06-22-2020, 01:39 PM | #6 |
Re: Pop Out Switch
06-22-2020, 03:56 PM | #7 |
Re: Pop Out Switch
06-22-2020, 05:09 PM | #8 |
Re: Pop Out Switch
OK, I though you maybe had an FSI Zipper distributor.
06-22-2020, 07:44 PM | #9 |
Re: Pop Out Switch
06-22-2020, 07:49 PM | #10 |
Re: Pop Out Switch
Yes and Yes
