02-04-2019, 09:12 PM | #1 |
Waltham speedometer question.
My 1931 Ford has a Waltham speedometer that I would like to have gone over or at least cleaned,especially the numbers. Not white on the indicator backgound but yellow. Is Waltham a good enough one to restore or cleanup or was the other makes better like Stewart Warner to just go with one already rebuilt?Thank You
"Never complain,never explain"... Henry Ford II |
02-05-2019, 02:25 AM | #2 |
Re: Waltham speedometer question.
Papanik?
02-05-2019, 07:59 AM | #3 |
Thanks but I don't understand the response.
02-05-2019, 11:38 AM | #4 |
02-05-2019, 11:50 AM | #5 |
To answer your question yes the Waltham is an excellent speedometer. The two posts above are Speedo rebuilders. Send your Waltham for a rebuild and rest easily.
02-05-2019, 11:58 AM | #6 |
02-05-2019, 12:26 PM | #7 |
The Waltham is a good speedometer, not as easy to work on as a Stewart Warner. There is only one means of calibrating the speed, whereas the Stewart has 2 adjustments. This makes the calibration easier and more accurate top to bottom. The yellow on the backround I believe is the change in color of the clear lacquer the factory put on top of the silk screened numbers to protect them. I have tried to use denatured alky to clean them and ended up wiping the yellow off and also the black number. If you need help, contact me.
Mark in MT Always looking for another opportunity to be wrong. |
02-05-2019, 12:35 PM | #8 |
I have cleaned the dial on one of mine that I thought was a goner with WD-40 on a soft rag, used very gently. Don't spray WD-40 on pot metal ever as it will cause old stuff to swell for some reason.
02-05-2019, 05:45 PM | #9 |
Hay always here to help you out. papanick. [email protected]
JUST SEND YOU A EMAIL WITH ALL THE INFO NEEDED ON GETTING THE SPEEDOMETER REBUILD. THAT FOR THE CALL. Last edited by papanick; 02-05-2019 at 07:53 PM. |
02-06-2019, 02:31 PM | #10 |
Mark has built some for me and does Excellent work and fast turnaround. Your choice! All do Great work that specialize in speedometers.
www.whidbeymodelaclub.com |
02-06-2019, 02:55 PM | #11 |
Papanick has done over 15 for me. Highly recommended. . Service & Quality is excellent. Gary in B.C. Canada
02-13-2019, 03:25 PM | #12 |
Hay did you get all the info needed on your speedometer. papanick.
