07-27-2014, 08:03 PM | #1 |
buzzer for signal flasher
A previous post mentioned a buzzer that could be attached to a turn signal flasher.. I'm confused as to where to attach the buzzer. My signal has three posts...X,L,andP.
What do these letters stand for and which ones would have the buzzer leads attached to them? Terry |
07-27-2014, 08:21 PM | #2 |
Re: buzzer for signal flasher
Mine is attached to "X" (power in) and "L" (signal switch). I think the "P" terminal is for a pilot light on the switch.
07-27-2014, 09:01 PM | #3 |
Mac's has the flasher with the buzzer together as one. Just plug it in.
Bill
The best way to have a friend is to be a friend. Howdy Doody |
07-27-2014, 10:28 PM | #4 |
If you decide to use a buzzer that is separate from the flasher unit, Radio Shack outlets typically stock a variety of small inexpensive 6 and 12 vdc buzzers that emit different levels of loudness. Be aware that it has been said that some buzzers do not last very long. Most I've seen are made in China.
Some complain about loudness but that depends what db (decibel) unit you buy AND where you install it. I choose a 75 db buzzer and installed it in the trunk under the shelf under the rear window .... which resulted in a good sound level. Your other option to control loudness is to cover the small speaker (only) with foam or tape or a combination of those. The buzzers have plus and minus wire leads and you simple reverse the wires if it doesn't work at the first try. Be careful not to wire the buzzer into the flasher wires that are part of the brake light circuit .... first-time-out I did and my buzzer sounded every time I put the brakes on. The buzzers are inexpensive so I ultimately decided to buy a second one and install them separately into the two wires that go to the front directional lights. This will lengthen the lives of the buzzers and avoids the brake light circuit. |
07-30-2014, 07:47 PM | #5 |
Went the cheaper route and got the buzzer from Radio Shack. Attached the leads to X and L and it works! The darn thing can get annoying if the turn signal is on for awhile,
but maybe that's good 'cause I make sure to cancel the signal quickly after making the turn. Thanks for the help fellas. |
07-31-2014, 01:43 AM | #6 |
Mart. |
07-31-2014, 11:37 AM | #7 |
I orginally bought one for my CJ2A jeep. There is so much noise that I was always leaving the signal on. I liked (or disliked) it so much I put one on my model A as well. A good safety feature for cars without self cancelling signals.
07-31-2014, 02:02 PM | #8 |
I bought one from Ron Francis Wireworks and it was loud. It just takes the place of the original flasher unit and plugs right in. I wrapped duct tape around it till it reached the level that I could hear and not forget it was on.
