10-06-2017, 06:02 PM | #1 |
Dimmer Switch Wiring - 41 Truck
I am wrapping up a new wiring harness on my '41 Truck - with the only remaining task is plugging in the dimmer switch. Sometime in the truck's history the wiring harness was replaced with wires of the same color - so I don't have the old harness to use as a reference.
My specific question is what lugs do the wires plug into at the switch ? My harness is a cloth covered replica with the correct colors, but I cannot find a diagram that shows which of the lugs each color plugs into. (I'm still searching ...) Thanks - |
10-06-2017, 06:16 PM | #2 |
Re: Dimmer Switch Wiring - 41 Truck
should be center connection for original switch, but with a multimeter should not be too hard to check out
10-06-2017, 06:29 PM | #3 |
