Old 04-29-2016, 03:29 PM   #21
Tom F OHIO
Tom F OHIO's Avatar
Default Re: Passenger Emergency Brake
Originally Posted by Tom Wesenberg View Post
Early parking brake bands have forged fittings for the toggles to pin to, and later bands had stamped.
These two pictures show the difference, and the bottom side in each picture is the side that MUST be against the carrier plate.
Ours is like the one that is rusted. Looking at your picture are the cotter pins facing in towards the carrier plate? Thanks again..
Tom F OHIO is offline   Reply With Quote
Old 04-29-2016, 06:23 PM   #22
Mel Gross
Are the E bands on the right way? There is an inner and outer to E bands! If they are on wrong, then the bands will not sit flush on the carriage and with be on an angle. All 4 of the pins should be head facing out and cotter pins on the inside.
Mel Gross is offline   Reply With Quote
Old 04-30-2016, 02:17 PM   #23
Zack
Zack's Avatar
Tom.
Does this help?
Zack is offline   Reply With Quote
Old 04-30-2016, 03:48 PM   #24
Tom F OHIO
Tom F OHIO's Avatar
Originally Posted by Zack View Post
Tom.
Does this help?
Yes it does, thank you. Your chassis sure looks nice. Is it painted or powder coated.
Old 05-01-2016, 08:34 PM   #25
Franchise_24
Franchise_24's Avatar
Happy to say we got the passenger side sanded some and the rods hooked up and both sides are working perfectly. Thanks for all the replies.
1929 Model A Ford Coupe
Franchise_24 is offline   Reply With Quote
Old 05-02-2016, 11:02 AM   #26
Zack
Zack's Avatar
Tom:
Everything is powder coated. I spent many a weekends grinding on all the parts to smooth out all the surface rust. I didn't intend to powder coat everything, but one thing led to another and well you can guess from there....
Zack
