Old 11-21-2020, 05:15 PM   #1
Krylon32
Default 40 Ford windnoise
I'm used to wind noise in my 32's but how much wind noise should I expect in my 40 standard coupe. I've got good wind lace around the doors and the window seals are all new and tight. I realize it will not be as quiet as my new Silverado but the noise in my coupe seems excessive? I really don't want to add sealing rubber as my doors close so nice and the rubber is not the most attractive.
Krylon32 is offline   Reply With Quote
Old 11-21-2020, 05:23 PM   #2
Lawson Cox
Lawson Cox's Avatar
Default Re: 40 Ford windnoise
Slow down. LOL
Old 11-21-2020, 05:30 PM   #3
fordy400
fordy400's Avatar
I know it is not proper but I installed two GM air vents in the back of the cab in my 40 Pickup and with windows up and cowl vent open you can carry on a conversation at 65 MPH
fordy400 is offline   Reply With Quote
Old 11-21-2020, 05:36 PM   #4
Kube
Kube's Avatar
It's difficult (obviously) to know if what you're experiencing is excessive for a '40 coupe.
They are not too noisy in my opinion. But yes, not nearly as air tight as a modern car.
There should be a seal at the front of the door between the hinges. Also, a seal that goes from the "B" pillar forward to the upper hinge on the body.
If those are absent, there's little to stop the wind from entering the car.
Old 11-21-2020, 05:37 PM   #5
19Fordy
19Fordy's Avatar
Gary, be sure to install the 1940 bottom door seals and sill plate. I never removed the doors and hinge pins are still nice and tight. No droop or drop. The door seals are actually quite resilient and do "crush" enough to allow good door closure. Also installed seals "Kube" mentioned. They are also resilient. Very little wind noise unless you open the windows at highway speed. Catalog is from the early days of DRAKE when he was in Canoga Park, CA.
Old 11-21-2020, 06:01 PM   #6
ford38v8
ford38v8's Avatar
Not all new seals are installed properly, even in modern vehicles. I bought a new pickup in 2014, which gave a loud howl at speed. The seals looked good, and the dealer even said they were good. Eight months later, the manufacturer put out a repair bulletin. They replaced my door seal with an identical seal, this time installed correctly.
Alan
Old 11-21-2020, 07:28 PM   #7
Willit Stop
Willit Stop's Avatar
Open the door and place a piece of paper on the rubber seal then close the door and pull on the paper. There should be a little resistance. Try it in several areas. At least you'll know where the wind noise is coming from. It may be as simple as adjusting the door.
Willit Stop is offline   Reply With Quote
Old 11-22-2020, 12:43 PM   #8
deuce_roadster
deuce_roadster's Avatar
Don't buy the seal Carpenter sells for the body above the door from the B pillar to the top hinge. The Drake one is the correct shape. What I got from Carpenter looks like it would fit a road grader, has a flange on it about 1 1/2 " wide. Maybe it was mis-labelled but more hassle and cost to send it back from my side of the US then its worth.
Old 12-13-2020, 09:49 PM   #9
hotrodA
hotrodA's Avatar
How good do your vent glasses fit to the divider bars?
Mine are not cut correctly and I get some noise.
Tim (OlScrounger on the HAMB) set me straight on that.
KUBE may have some input on that as well.
hotrodA is offline   Reply With Quote
Old 12-14-2020, 11:25 AM   #10
19Fordy
19Fordy's Avatar
hotrodA: The vent window felt and seal fit good on my 40 Ford. Took lots of patience to get it all adjusted so the windows roll up and down easily. Steering wheel is Crestliner.
Old 12-19-2020, 01:18 PM   #11
hotrodA
hotrodA's Avatar
Thanks!
Those DO fit up nice. I think that my door glass rises at an angle, creating the gap.
I’m not ready right now to pull the window frames and door panels to elongate the left mechanism holes and adjust it. Lazy.
Old 12-19-2020, 05:11 PM   #12
19Fordy
19Fordy's Avatar
hotrodA: I understand. When you do decide to readjust be sure to have plenty of patience and be very carful not to crack the glass. You have to have the patience of a toothache and walk away from it when you get frustrated.
Old 01-13-2021, 08:08 AM   #13
3wmike
Hi, I`m interessed in buying a set of brake plates Krylon32 but I can`t send you a PM cause FordBarn said I must have 10 posts, so can you send me a PM with your e-mail adress
Thanks Michael
3wmike is offline   Reply With Quote
Old 01-13-2021, 10:05 AM   #14
19Fordy
19Fordy's Avatar
Mike, You can contact him on his website:
http://cornhuskerrodandcustom.net/
