Old 11-19-2020, 04:43 PM   #1
adileo
adileo's Avatar
Default 52 f1
Hi guys, I hope, I can describe this as it’s has happened a few times with no regularity.
So recently took a run to the store about 10 mikes away. Truck ran perfectly. I pulled in lot, pulled emergency brake and shut truck off. After leaving the store truck started right up, released emergency brake put in first and pulled out of parking lot and then stopped for light. Here is where my issue starts. When light turns green, it almost feels like my brakes are locked. I immediately push clutch in rev engine and try again. Truck responds as it should and I drive about 3 miles. Stop for light and it does it again. I again repeat what I did earlier and then truck drives all the way home with no issues.
I’ll pull all wheels off and check brakes but should I look at anything else? It’s weird that for most trips truck is fine.
Thanks
Andy
1952 F1
adileo is offline   Reply With Quote
Old 11-19-2020, 04:59 PM   #2
FortyNiner
FortyNiner's Avatar
Default Re: 52 f1
Checking the brake cable action would seem to be the first troubleshooting step.
Old 11-19-2020, 05:42 PM   #3
alanwoodieman
Default Re: 52 f1
adjusted too tight? heat made them expand and lock up, short shoe to front
Old 11-19-2020, 05:47 PM   #4
adileo
adileo's Avatar
Default Re: 52 f1
Thanks guys.
Brakes have 10k on them. I’ll pull drums see if anything amiss.
Just strange that it happens and then goes away.
Thanks
Andy
1952 F1
Old 11-19-2020, 08:18 PM   #5
TJ
TJ's Avatar
Default Re: 52 f1
Sounds like a wheel cylinder may be sticking.
Old 11-19-2020, 08:28 PM   #6
adileo
adileo's Avatar
Default Re: 52 f1
TJ that is very possible.
I’ve seen them leak and have replaced. Is there a tell tail sign or a test I can do? I’m assuming not, since it’s intermittent.
Thanks
Andy
1952 F1
Old 11-19-2020, 08:29 PM   #7
paul2748
paul2748's Avatar
Default Re: 52 f1
Possible internal collapse of a flex line or lines. How old are they?
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 11-19-2020, 08:40 PM   #8
adileo
adileo's Avatar
Default Re: 52 f1
Paul
Thanks, while the sticking wheel cylinder sounds more likely. Your idea is also possible. I can’t recall if I replaced them when I purchased the truck 3 years ago. I’ll look into both suggestions.
Thanks
Andy
1952 F1
Old 11-20-2020, 11:24 AM   #9
1948F-1Pickup
1948F-1Pickup's Avatar
Default Re: 52 f1
You'd be surprised on the rate of occurrence on the collapsed flex line.
There's even a fair percentage of mis-manufactured flex lines where
the ID passage necks down.... those are really a pain to diagnose.
(story is too long to relate here, but I've seen that issue personally too)
Unless you've messed with the factory master cylinder setup in some way,
my money is on the wheel cylinder.
1948F-1Pickup is offline   Reply With Quote
Old 11-20-2020, 02:02 PM   #10
Mart
Mart's Avatar
Default Re: 52 f1
A piece of brake lining may have come dislodged. Not likely if the brakes are relatively new.
A good inspection of all the brake assemblies is called for.
If you go for a ride on quiet roads with a helper, and drive in a manner to cause the problem to reoccur, the helper can jump out and observe the wheels as you attempt to move. You might be able to identify which brake is hanging up.
Mart.
Old 11-20-2020, 02:11 PM   #11
Als48
Default Re: 52 f1
You might check to see if the brake lights are on when this occurs. That would indicate a sticking master cylinder. Probably not likely though.
Al Hook
Als48 is offline   Reply With Quote
Old 11-20-2020, 02:14 PM   #12
Ross F-1
Ross F-1's Avatar
Default Re: 52 f1
Can you tell if it's all the brakes, or just one wheel? If it's all of them, the residual pressure valve in the MC may be bad.
I had some drag when releasing the e-brake and backing up. It turned out to be a bad axle seal on the right rear, oil all over the shoes. 90wt is a good adhesive!
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 11-20-2020, 02:23 PM   #13
adileo
adileo's Avatar
Default Re: 52 f1
Thanks guys.
I think, it feels like both back brakes locked up. I’m now thinking, the suggestion on the one flex hose that feeds both is probably going bad.
I will still inspect all four wheels starting with back. I will replace the hose.
Thanks
Andy
1952 F1
Old 11-20-2020, 04:28 PM   #14
Ford Freak
Default Re: 52 f1
^^^ I do believe you are on to something here ^^^......F F
Ford Freak is offline   Reply With Quote
Old 11-22-2020, 10:16 AM   #15
adileo
adileo's Avatar
Default Re: 52 f1
Hi Guys
I changed rear flex brake line.
What’s interesting is when I disconnected the line. Absolutely no brake fluid dripped out.
Master cylinder was full and when I depresses the brake peddle brake fluid came out the open line. I installed new flex line and bled out air. So far so good.
Thanks
Andy
1952 F1
