Old 08-13-2019, 08:17 PM   #1
evobuilder
evobuilder's Avatar
Default 1932 ford frame differences
How many different Ford frames were available in 1932?
I’ve heard three, but not sure what each would be and what the differences are.
I know the most common is the frame with the scallop design on the outer frame rails. What are the others?
I searched here and online for answers but haven’t found the answer yet. Anyone have some knowledge on this?
evobuilder is offline   Reply With Quote
Old 08-13-2019, 08:31 PM   #2
VeryTangled
VeryTangled's Avatar
Default Re: 1932 ford frame differences
I wonder... 1932 Fords... Hmmm.
-Jeff H
Old 08-13-2019, 08:40 PM   #3
evobuilder
evobuilder's Avatar
VeryTangled.... your comment makes no sense, are you being a smart ass or just did not finish your thought? My question is worthy of feedback from those with knowledge on Ford history.
Old 08-13-2019, 08:52 PM   #4
Andy
I have only seen one 32 frame without the roll on the bottom. The owner had beat it flat because he though it was from damage.
David can elaborate about all the running design changes. The rails stayed the same but with reinforcing plates late. The front and center crossmembers had a few changes. They all looked basically the same.
Andy is offline   Reply With Quote
Old 08-13-2019, 09:00 PM   #5
evobuilder
evobuilder's Avatar
Thanks Andy.... I cannot locate David G (?) in search, any idea how to add him to this thread?
Old 08-13-2019, 09:11 PM   #6
deuce_roadster
deuce_roadster's Avatar
Andy pretty much covered it. All 3 crossmembers had differences throughout the production run. I believe the K member had the most changes, maybe 4. I think the rails did not change. DavidG literally wrote the book on this subject and hopefully will chime in.
Old 08-13-2019, 09:18 PM   #7
evobuilder
evobuilder's Avatar
thanks deuce_roadster.... hopefully this caught @DavidG's eye.
Old 08-13-2019, 09:30 PM   #8
qmdv
qmdv's Avatar
I have never seen a 32 frame without the scallop. Model T's and A's had the bodies above the frame and running boars below the frame. The frames were hidden behind splash aprons. In 32 there were no splash aprons so the frame was exposed to the public. So the scallop followed the flow of the fenders.
qmdv is offline   Reply With Quote
Old 08-13-2019, 11:02 PM   #9
DavidG
DavidG's Avatar
It depends on how you define 'difference'. Apart from the differences between LHD and RHD frames, there were three distinctly different front cross members, three different center cross members, two different rear cross members, and three different sets of side rails (not counting the undocumented side rails without the ridge above the running boards). Some of those changes took place at the same time, so the net number of different frame configurations is at least six for LHD frames that I can document.
DavidG is online now   Reply With Quote
Old 08-13-2019, 11:21 PM   #10
Newc
Newc's Avatar
The original post did not specify car or 1/2 ton? I have the big trucks 'BB' and they use passenger fenders/hoods , and are curved toward the front half. Newc
Old 08-13-2019, 11:31 PM   #11
DavidG
DavidG's Avatar
'32 passenger car and commercial vehicle (pickup, station wagon, panel delivery, and sedan delivery) frames were the same at any given time during the model year depending on assembly plant inventories.
Old 08-14-2019, 12:23 AM   #12
evobuilder
evobuilder's Avatar
OK, I am trying to understand the different frame options for 1932 passenger cars, specifically, the frame rails and what the differences are in the 32 frame rails (with scallop design, without scallop design. Length and overall width differences.
Old 08-14-2019, 01:27 AM   #13
deuce lover
deuce lover's Avatar
Arrow Re: 1932 ford frame differences
Here is a chassis a friend has and the frame has no scallop
File Type: jpg 32 Ford French chassis - no reveal.jpg (170.6 KB, 238 views)
Old 08-14-2019, 03:54 AM   #14
Mart
Mart's Avatar
The rear crossmembers were changed to accommodate the strengtheners fitted over the rear axle.
Old 08-14-2019, 07:53 AM   #15
DavidG
DavidG's Avatar
The overall length and width of the passenger car/commercial vehicle frames were unchanged from job #1 to last job.
I'll amend my statement above to confine it to North American production as the photos Sheldon has provided are of a European frame.
Mart,
There were two versions of those reinforcements (in North American production). The first were attached outside the frame and could be fitted post production and the second were spot welded to the inside of the frame rails necessitating a shortening of the rear cross member. The first versions were used only very briefly and are rarely encountered on surviving frames.
Old 08-14-2019, 12:08 PM   #16
glennpm
glennpm's Avatar
Hi Evobuilder, do you get it now? ;-)
"I wonder... 1932 Fords... Hmmm"
DavidG Rehor is our expert! Buy his books if you want to know everything about '32s He ALWAYS helps on this site.
https://shop.efv8.org/collections/fo...tbound-all-new
Old 08-14-2019, 12:09 PM   #17
woodiewagon46
As David mentions there were probably dozens of small changes to the '32 frame. When people say all Model A frames were the same I have to laugh. There were four major changes and over two dozen minor changes such as added and deleted bolt holes, changes in bolt hole sizes, etc.
woodiewagon46 is offline   Reply With Quote
Old 08-14-2019, 12:22 PM   #18
Kube
Kube's Avatar
Mart,
Dave, you continue to amaze me.
Kube is online now   Reply With Quote
Old 08-14-2019, 12:43 PM   #19
DavidG
DavidG's Avatar
Thanks, guys!
Old 08-14-2019, 12:56 PM   #20
bluardun
bluardun's Avatar
Ah no: THANK YOU DAVID. Your knowledge and taking time to share it is always appreciated.
bluardun is offline   Reply With Quote
