04-24-2011, 03:07 PM | #1 |
What is the correct carburator for a Model B
What is the correct carburator for a 1932 4 cylinder Model B(MAY PRODUCTION), and also which one would have the best performance? Thank you in advance for your consideration, and for any pics of the RIGHT CARB!
04-24-2011, 04:38 PM | #2 |
Re: What is the correct carburator for a Model B
This site has some good information: http://www.fordgarage.com/. Have you checked out "The 1932 Ford Book" from the Early Ford V8 Club? My copy is out on loan right now but it probably has the exact data you need. You should fill out your profile.
Charlie Stephens |
04-24-2011, 04:46 PM | #3 |
It will be a Zenith with a cable running off the choke/jet adjuster, 32s have a boxey float chamber compared to the rounded float chamber on Model As.
04-24-2011, 08:42 PM | #4 |
Keoki. I sure like the license. Did you do that up yourself or is that an allowable item in Hawaii now?
Aloha Jim |
04-25-2011, 02:06 PM | #5 |
