Old 04-18-2018, 11:14 AM   #21
Ron in Quincy
Ron in Quincy's Avatar
Default Re: Oil mist on left side of engine
btt
Ron in Quincy is offline   Reply With Quote
Old 04-21-2018, 03:36 AM   #22
woofa.express
woofa.express's Avatar
Originally Posted by Ron in Quincy View Post
You can use a plain copper scrub pad, cut a large piece and place it in the tube under the oil cap, push it down to the louvers. As the oil collects on the pad it will run back into the oil pan and not end up on the left side of the engine.
Works well for me for a lot of years.
Ron
good one Ron.
woofa.express is offline   Reply With Quote
Old 03-14-2019, 03:57 PM   #23
nevadavic
After reading several "breather pipe" topics, I thought the solution would be to use a Model B breather tube since it is a Model B engine. Well, that didn’t work since there was an after-market finned aluminum side cover on the engine which stated; "this plate will fit Model B engines if the Model A oil filler pipe is used."
Other respondents said that extending the length of the breather tube was a solution. So I came up with this modification; a piece of leftover 1-1/2" radiator hose, a cut down Ace Hardware black plastic 1-1/2" dia. polypropylene tailpiece (4223848), a couple hose clamps and the original cap. The cap fit the tailpiece perfectly.
It works great! No more oil mist in the engine compartment and only a couple drops of oil under the bell housing. No, it's not pretty or "stock" looking but can be removed quickly to add oil or removed entirely when at a car show.
I did also take the advice of several respondents of keeping the crankcase oil level halfway between the "F" and "L" level on the dip stick.
nevadavic is offline   Reply With Quote
Old 03-14-2019, 10:47 PM   #24
Smooth_One
Smooth_One's Avatar
Anyone know the best way to clean the inside of the fill tube??
Isaiah B.
1928 all metal Tudor
Smooth_One is offline   Reply With Quote
Old 03-15-2019, 09:23 AM   #25
Jeff/Illinois
Jeff/Illinois's Avatar
I can see why you'd want to keep THAT engine bay clean Nice!
Old 03-16-2019, 02:27 PM   #26
Purdy Swoft
Purdy Swoft's Avatar
I like and use the Fumaze crankcase breather . These breathers are no longer produced but sometimes come up on eBay . All engines have some blow by and have or need a crank case breather . The model A has NO crank case breather and needs one . The Fumaze has a quaint look and are an old accessory that works very well . The Fumaze looks similiar to the crank case breathers used on the old stove bolt chevy sixes . Mine clears the engine pans and could easily be replaced with an original for show use .
Old 03-16-2019, 05:17 PM   #27
Werner
Werner's Avatar
Hello Purdy,
is it possible, to show a picture from this part?
Thanks!
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 03-16-2019, 06:05 PM   #28
Purdy Swoft
Werner , Sorry but I can no longer post pictures . Its mostly a thing about resizing the pictures to get them to post .
Old 03-16-2019, 06:28 PM   #29
Benson
Benson's Avatar
here
Post 4 shows link to Snyder's
Find a fumaze if possible as they are less restrictive than flexible ones like I had 50 years ago.
Old 03-16-2019, 08:18 PM   #30
Purdy Swoft
Thanks Benson for the picture of the old ad
Old 03-16-2019, 08:43 PM   #31
Dutie
Dutie's Avatar
# 7.... I agree the scrubby works for me also. Have used it for years and works well, mine happens to be stainless and will not come apart and is really course, allows for easy flow and no blow by. good luck with yours. Dutie
Dutie is offline   Reply With Quote
Old 03-17-2019, 07:34 AM   #32
Werner
Werner's Avatar
Thanks Benson and Purdy!
Werner
Citroen 11 CV, 1947
Old 03-21-2019, 09:59 AM   #33
DHZIEMAN
Originally Posted by mgtf1500 View Post
I have a car that mists oil form somewhere -- Breather Cap? Dip Stick hole - some other unknown place. Where does this mess come from and how do I fix it?
!931 Deluxe Delivery
Thanks again.
I had similar issues of oil wetting on my engine! I had just purchased the car, and had only run it to town and home, and oil wetting on the left side was obvious! Did some looking and investigating and found my oil filler tube was loose in the block! Once I pulled the breather cap, I was able with little effort to pull out the entire oil fill tube. So, I put some permatex on the oil tube, shoved it back in and checked the oil level, took the old girl for a ride and no more oil wetting!
DHZIEMAN is offline   Reply With Quote
