Old 11-12-2016, 02:03 PM   #1
Kevin in NJ
Default Carbs and paint...
I am aware of some of the model airplane paints that were always used. They just are no available anymore.
Doing a basic search for fuel proof paint I found this brand:
VHT Paint
It is available through a number of retailers locally to everyone.
Which brings me to the question of which type of paint? Gloss, Satin or Flat?
I have to go look it up still, but any input would be good. I need to paint up a carb or 2.
Thanks!
Old 11-12-2016, 03:11 PM   #2
ursus
Default Re: Carbs and paint...
I would go with flat. I've seen some unused original carbs and there was no sheen.
Old 11-12-2016, 03:59 PM   #3
lindy williams
Originally Zenith carbs had a dull black surface. Not glossy.
lindy williams is offline   Reply With Quote
Old 11-12-2016, 04:04 PM   #4
Larry Jenkins
VHT Paint
Thanks!
I have used the VHT paint on my chassis and other parts that originally had the Satin look. VHT is an epoxy based "high gloss" paint that dries with the right sheen to match the original carb paint.
I used it on my Zenith 2 and I like how it looks.
Good enough.. Isn't.
Larry Jenkins is offline   Reply With Quote
Old 11-13-2016, 01:01 AM   #5
Mike V. Florida
Mike V. Florida's Avatar
Look up full size aircraft suppliers to find dope. the gloss can be cut by adding talcum powder. it's about 22.00 a quart.
Old 11-13-2016, 01:42 AM   #6
forever4
I have not used it myself, but this might be a good choice.
Epoxy is not desirable, nor is high temperature a need for a Zenith.
What is important for carburetors is fuel resistance.
http://www.vhtpaint.com/motorsport/vht-black-oxide-case-paint
Try Ford Garage Search
forever4 is offline   Reply With Quote
Old 11-13-2016, 10:34 AM   #7
Gary WA
Gary WA's Avatar
We all have our choices! Here's what I use when rebuilding carbs,available at Hobby Stores and Amazon.
www.whidbeymodelaclub.com
Old 11-13-2016, 11:35 AM   #8
Mitch//pa
I use this easy to get lacquer paint which has held up real well ...it resists fuel also and is recommended on snyders web site for doing carbs...
Old 11-13-2016, 01:10 PM   #9
Gary WA
Gary WA's Avatar
http://www.activepowersports.com/top...rMXhoC16zw_wcB
Originally Posted by forever4 View Post
Gary,
I agree with you 100%, and have promoted TopFlite on the message board for 10 years, but it does not seem to be available in black anymore, even direct from Topflite. It seems they are only making red and yellow now.
Earlier this year I spent some time trying to find some and came up empty. A couple of web sites showed it, but actually had none to sell. Top Flite removed it from their own web site. Is it available again?
If you know who still has it today, please share. I'd like to get a few more cans. Thanks
Old 11-13-2016, 06:35 PM   #10
1crosscut
1crosscut's Avatar
Gary, thanks for the link. I just ordered 5 cans from them. I hope that they indeed do have it in stock. The paint is bullet proof when it comes to gasoline. The carburetor paint from Snyders looks real nice and resists gasoline a little bit but is definitely not fuel proof.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 11-13-2016, 10:19 PM   #11
larrys40
Like Vince and many of you I have used the top flite fuel proof paint wit very good results, like Vince I have tried to find it in black and have been unsuccessful... However, short term till it comes available I purchased it in satin clear ( I believe also discontinued ) and the gloss clear.
I coated with the automotive dupli color black with ceramic and then too coated with the top flite clear . I have had good results so far
I will try the VHT above and see how it does.
I concur that it is a dilemma right now but hopefully we can get a good solution soon.
Please continue to post with results .
Larry Shepard
larrys40 is offline   Reply With Quote
Old 11-14-2016, 06:42 PM   #12
d.j. moordigian
d.j. moordigian's Avatar
Vince and Kevin..
You can still buy dope here,....
http://brodak.com/finishing-products...odak-dope.html
Dudley
d.j. moordigian is offline   Reply With Quote
