Old 02-17-2013, 08:39 AM   #1
Double A
Angry deciphering the year from engine block serial numbers
How do I figure out the YEAR of my ModelAA Truck from the serial number on the engine block? The info I've found on the web doesn't seem to go back to the 1920s. It concentrated on autos from the 1950s and up.
~Gene and Beth~
Double A is offline   Reply With Quote
Old 02-17-2013, 08:52 AM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: deciphering the year from engine block serial numbers
You need to look at several truck details to establish the year. Do you have any pictures? What is the engine number? Engines are easily and often changed, so the number may or may not be of some help.
Old 02-17-2013, 08:58 AM   #3
lance leblanc
lance leblanc's Avatar
Do you know that this is the original engine to the truck?
You may find more info here.
http://www.fordgarage.com/pages/ABenginenumbers.htm
Lance
"When Solomon said there was a time and place for everything he had not encountered the problem of parking his automobile." Bob Edwards
lance leblanc is offline   Reply With Quote
Old 02-17-2013, 09:50 AM   #4
Bob Johnson
Bob Johnson's Avatar
See link below
Bob
LINK
Bob Johnson is offline   Reply With Quote
Old 02-17-2013, 11:57 AM   #5
lajones
lajones's Avatar
I just looked the one up for my late 31 CCPU, steel top, indented firewall and the engine date is 1/17/29. I have titles dating back to 1969 with this number. So it was either changed out prior to 1969 or was a really left over block...
lajones is offline   Reply With Quote
Old 02-17-2013, 12:34 PM   #6
Steve Plucker
If the block is an original stamped block, not a reground and restamped, then you can go to Bob's site or mine and figure out the day of the original stamping.
However, if it is a reground, and restamped block, there are several ways you can get it to within a certain time frame.
Pluck
Old 02-18-2013, 07:06 PM   #7
Double A
You are the absolute BEST!! Thank you. This group of people are the Gold Mine of Great People!!
~Gene and Beth~
Old 02-18-2013, 07:08 PM   #8
Double A
Boy oh Boy...it takes alot of Ford Friends to figure this out !! *Fun* Thank you
~Gene and Beth~
Old 02-18-2013, 07:10 PM   #9
Double A
Ive heard "restamped" a few times. Who and Why did they do this?
~Gene and Beth~
Old 02-18-2013, 07:13 PM   #10
Tom Wesenberg
IF the motor gets changed they might grind off the old number and stamp their old bad engine number onto the new engine, so it still matches the title. Rather than grind, I'd use a punch to work out the old number and restamp the new number, so you still have the original cast pad surface.
Old 02-18-2013, 07:19 PM   #11
Double A
Thumbs up Re: deciphering the year from engine block serial numbers
Bob, THANK YOU SOOOO much for helping us find the Birth Certificate Date of our newly Adopted Model AA truck. I can't believe you have the exact DAY ! We feel so much closer to her now LoL
~Beth and Gene~
~Gene and Beth~
Old 03-04-2013, 09:33 PM   #12
QGolden
QGolden's Avatar
Is this a re-stamped engine or a spares?
It's not what people think they know that will hurt them, it is what they think they know that aint so! -Mark Twain.
It is the very things that we think we know, that keep us from learning what we should know.- Unknown
QGolden is offline   Reply With Quote
Old 03-04-2013, 09:47 PM   #13
Mike V. Florida
Mike V. Florida's Avatar
The smoothness of the area where the numbers go (the pad), the position of the numbers, the size of the numbers and the missing star in front and after the number says it is a restamp.
Old 03-04-2013, 10:05 PM   #14
QGolden
QGolden's Avatar
I thought likely. I have often wondered what the significance of the sideways "4" is. It must have meant something to someone.
