08-16-2019, 12:25 PM | #1 |
coil polairty
on a 6v positive ground system does the ign wire go to the -neg and the pos go to the distributor or vice versa
08-16-2019, 12:41 PM | #2 |
Re: coil polairty
Just like you said,ign wire to neg on coil.
08-16-2019, 01:02 PM | #3 |
Re: coil polairty
The ignition wire from the coil to the distributer matches your battery ground. The wire from the coil to the points is the ground path for the coil. So, yes, on a (+) ground car the distributor wire connects to the (+) terminal on the coil.
08-16-2019, 01:30 PM | #4 |
Re: coil polairty
just what I thought someone had them reversed
08-16-2019, 05:43 PM | #5 |
Re: coil polairty
