Old 06-19-2021, 03:39 PM   #1
frank d kirkstad
Default Mitchell overdrive in 36 ford coupe
Have the Mitchell overdrive units been changed or modified or will I still have to modify my rear floor by cutting an opening to make room? I have a 36 standard coupe.
Thank You. Frank
frank d kirkstad is offline   Reply With Quote
Old 06-19-2021, 07:52 PM   #2
Kube
Kube's Avatar
Default Re: Mitchell overdrive in 36 ford coupe
Thank You. Frank
You'll need to cut the floor.
Old 06-19-2021, 08:17 PM   #3
koates
Yes as above, you will need to open up the floor where the trans tunnel meets the step up in the rear floor. I friend of mine had to do this on his coupe. I dont believe the overdrive box has been modified. Call them and ask the question. Regards, Kevin.
koates is offline   Reply With Quote
Old 06-20-2021, 07:38 AM   #4
Ford Freak
Yes, you will have to modify the floor in one area.
1952 Ford F1
1965 Ford Falcon Sprint
2007 Ford Mustang GT
Ford Freak is offline   Reply With Quote
Old 06-20-2021, 09:32 AM   #5
Planojc
Planojc's Avatar
FYI, I put one in my 39 Std. Coupe and the only thing I had to do was to hammer the corners at the tunnel just a little for clearance but I didn't have to cut any of the floor.
Planojc is offline   Reply With Quote
Old 06-21-2021, 05:11 AM   #6
flatmotor40
flatmotor40's Avatar
Put one in my 40 had to do nothing to floor except put the shift arm to the bottom.Now you pull cable to engage OD and push in to disengage OD.Hit a bump with someone in back seat and it would touch floor
flatmotor40 is offline   Reply With Quote
