Old 04-08-2016, 08:30 PM   #1
ford-m
ford-m's Avatar
Default Original VS reproduction 1929 Roadster
Tried to replace my gas guage and the reproduction outer nut is very poor fit. My original nut threads very smoothly but the repo is so loose I'm afraid to try to tighten it up.
My original
The reproduction
Video
http://vid1291.photobucket.com/album...psefgiq2l8.mp4
ford-m is offline   Reply With Quote
Old 04-08-2016, 09:13 PM   #2
C26Pinelake
Default Re: Original VS reproduction 1929 Roadster
Why not use the old one on it then ? Wayne
C26Pinelake is offline   Reply With Quote
Old 04-08-2016, 10:07 PM   #3
MikeK
MikeK's Avatar
Think restore not replace. You have a good original, just have it re Nickel plated. That Chrome repop would look wrong even if the thread was correct.
MikeK is offline   Reply With Quote
Old 04-09-2016, 05:13 AM   #4
Mitch//pa
The outer repo nut is an issue as you found out... Do not use it as the threads are off..I tried more than one then sent them back for a refund
Old 04-09-2016, 06:22 AM   #5
2manycars
2manycars's Avatar
If you have it re nickeled, have them mask the threads. I had some done and the plating was so thick they were useless. Also, ask for nickel only, as the copper undercoat is not needed with brass.
Bill
www.brauchauto.com
2manycars is offline   Reply With Quote
Old 04-09-2016, 07:40 AM   #6
barry022
The bad one you sent back is turned around and then sent out to another unsuspecting customer.
barry022 is offline   Reply With Quote
