Old 10-04-2021, 09:43 PM   #1
Lakesmodified
Lakesmodified's Avatar
Default Measurement Needed 51 Vicky
So I recently purchased a 51 Vicky
I noticed something that wasn’t right at the rear spring purches, so I’m needing a measurement, to figure out if my springs are weak, or if someone decided to change the shackles to the bottom in order to raise the rear of the car. I was planning on buying new springs, but now I’m not sure if I should be dropped springs or standard springs. What I need, is the distance between the opening of the rear fender Wells to the centerline of the rear axle. I took a couple of pictures, along with the one showing that the previous owner had flipped the shackles. Mine is approximately 9.25”
I’m trying to figure out what’s the original factory measurement. Thanks in advance. Ivan
UNFORTUNATELY CANNOT LOAD PICTURES
Lakesmodified is offline   Reply With Quote
Old 10-04-2021, 10:35 PM   #2
VeryTangled
VeryTangled's Avatar
Default Re: Measurement Needed 51 Vicky
Pic posting help... 4 minute video.
https://youtu.be/sdP9Bvbojoo
-Jeff H
Old 10-05-2021, 12:37 AM   #3
V8COOPMAN
V8COOPMAN's Avatar
Ivan .....If ya still don't have the picture-posting figured-out, e-mail them to me and I'll post 'em here on the 'Barn for ya. My e-mail below! DD
[email protected]
Click Links Below __
T5 W/TORQUE TUBE
Old 10-05-2021, 11:36 PM   #4
V8COOPMAN
V8COOPMAN's Avatar
Here are your pictures, Ivan! DD
T5 W/TORQUE TUBE
Old 10-06-2021, 08:22 AM   #5
flatford8
flatford8's Avatar
The shackle should be up…… Mark
You might have to be laying down for that to look right !!
File Type: jpeg 2FC8278E-D3F9-431F-AF05-7B83A278F0F1.jpeg (87.8 KB, 24 views)
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver
Old 10-06-2021, 09:15 AM   #6
Lakesmodified
Yes, I’m aware that a previous owner flipped the shackles, what I’m looking for is the distance from the fender opening to the centerline of the axle(center of the wheel) I’m going to replace the springs, and plan to install the shackles correctly, I’m just trying to figure out how much my springs are sagging
Old 10-06-2021, 09:19 AM   #7
Lakesmodified
[QUOTE=V8COOPMAN;2063992]Here are your pictures, Ivan!
Thank you sir. My home computer is on a slow network, so I’m doing all my posts from my iPhone
Old 10-06-2021, 09:55 AM   #8
tubman
tubman's Avatar
If it helps, I'll measure my '51 Club Coupe on my way back from town later this morning. The car was a good original that I went through, including disassembling, cleaning, and lubing the original springs, so it should be pretty close to stock. The shackles are in the stock (up) position.
Old 10-06-2021, 11:52 AM   #9
tubman
tubman's Avatar
I just got back from my shop. My car measures 8 3/4" for that dimension. There may have been a difference of 1/16" or so from side to side, as it is a little difficult to find the exact center of the stock hubcaps, but it's very close.
Old 10-06-2021, 12:28 PM   #10
Lakesmodified
Thanks, that does help a lot; mine are approximately 9.25” and that’s with the shackles reversed, so my springs have definitely sagged quite a bit. I guess I’m going to order regular height springs, since I really don’t like the back lower than the front. Thanks again
Old 10-06-2021, 02:18 PM   #11
Lanny
Lanny's Avatar
Ivan, here is a picture of a '51 Vicky that appears fairly stock.
As you can see, the wheel opening lip is about at the top edge
of the wheel.
The wheel is 15", so measuring down to the center of it,
you would get a measurement of about 7 1/2".
Click on picture to Enlarge
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
Lanny is offline   Reply With Quote
Old 10-06-2021, 02:29 PM   #12
tubman
tubman's Avatar
Isn't the tire mounting surface 15" in diameter? If you account for the flange that holds the tire on, it's close to what I measured.
It's pretty hard to believe that I picked up an inch and a quarter by what I did to my springs (I did not have them re-arched). Unless we know what has been done to the Victoria pictured, it's hard to know exactly what's going on. Sevety tears of use can have it's effect.
Old 10-06-2021, 07:51 PM   #13
Ken Henry
Ken Henry's Avatar
Going out on a limb here, but I think flipping the shackles back to normal may lower it one shackle length, might be ok
Ken Henry is offline   Reply With Quote
Old 10-06-2021, 09:35 PM   #14
Lakesmodified
of the wheel.
Thanks, beautiful Vicky
Old 10-06-2021, 09:49 PM   #15
Lakesmodified
I would think if I flipped those shackles back that the rear would be sitting about 4” lower; from my guesstimate now, after seeing what stock looks like, I would say that my springs have sagged approximately 2”
Thanks Ken
Old 10-06-2021, 10:24 PM   #16
Lanny
Lanny's Avatar
Ivan, here is another '51 Vicky that appears fairly stock.
The rear wheel opening lip also looks like it would line up
close to the top of the wheel.
The other Vicky with the white top, and this one with the
black top both look like they sit about the same height.
But, just looking at the pictures is the best I can do, I
don't have any actual measurements for you...sorry
Old 10-07-2021, 12:23 AM   #17
Lanny
Lanny's Avatar
OK, one last picture of an artists rendering of a NEW 1951 Victoria
shown in a Ford poster.
It shows the wheel opening lip of the quarter panel to also be
very close to the top of the wheel.
