06-24-2013, 04:15 PM | #21 |
Re: Logan
On a piston a scupper is a drain relief for the oil control ring assembly. It may be a series of holes through the land into the interior of the piston. In the case of slipper design pistons with flattened, reduced sides adjacent to the pin bosses, the scupper (drains for the oil ring) are sometimes directed into this area rather than the piston interior. I doubt that is what the OP of "scupper" was referring to, but that's what a scupper on a piston is.
As far as having a qualified third party disassemble it, yes, it does matter. I've already heard plenty of gobbledygook speculating here, especially about the discoloring of the rod small ends, which is NORMAL when installing chevy style pins. I'd be concerned if the pins were installed without heating the rod small ends. You heat the ends to ~ 600-700F so the cold pins can be tapped in without excessive force. If you dry-ice the pins they just drop through the piston and the hot con-rod with no hammering. Some driving with a proper tool that does not touch the piston pin bore is normal. Was there inspection of the ends of the pins for evidence of excessive assembly force on the tight one? What measurements were taken during disassembly? Were the pistons measured for diameter and requisite eccentricity? Were the bores measured for concentricity and taper? Have all the ring end-gaps been measured? There may have been nothing wrong at all with that part of the build. Factors under operator control may have caused the piston expansion and seizing. On the positive side, looking at the pictures it does not appear the lock-up froze the rings in their lands, and it also appears the rings kept the aluminum buildup confined to the area below the ring travel. When that happens there is usually no real damage to the cylinder walls, they clean up easily for new pistons and rings. When the rings lock up is when you get wall damage. I built plenty of SBC (gasp!) track motors in the 70's and a build that ran fine all season could lock pistons like yours in one lap with an intake leak (lean cyl), a carb jet or an ignition timing change. OOPs! |
06-24-2013, 05:20 PM | #22 | |
Re: Logan
06-24-2013, 06:14 PM | #23 | |
Re: Logan
If that happens I'll have to delete Fordbarn from my Favorites list and quit reading it, as there won't be much here worthwhile to read anymore........... Stop,,,,,, please. |
06-24-2013, 06:19 PM | #24 |
Re: Logan
I'm OK guys. It will be OK for all concerned when enough time has passed.
06-24-2013, 06:27 PM | #25 | |
Re: Logan
i think you should delete this like you did your other 900 posts you used to have Last edited by Mitch//pa; 06-24-2013 at 06:44 PM. |
06-24-2013, 06:29 PM | #26 |
Re: Logan
Jamie Crosson 1929 Tudor Looking for an Original 888 Key |
06-24-2013, 06:29 PM | #27 |
Re: Logan
Hay Roy, how many times have I heard you and THE NOSE wining about name calling.
Does this mean the rules have changed, "OH BOY"!!!!!!! I have always wanted to use the word Bozo!!!!!! So here go's. What you two Bozo's done was flap your lips, to wear Logan had to defend him self from posts that were a waste of the space they were writen on. You two are always riding each other's wagon any way. |
06-24-2013, 06:34 PM | #28 | |
Re: Logan
06-24-2013, 06:42 PM | #29 |
Re: Logan
And I would say you are more immature than my 5 year old for saying that... Your "contribution" that you just made to this thread does nothing positive at all. Time to grow up some and act like an adult... That's the problem with the internet...people spout off and say things they wouldn't have the guts to say to someones face in real life. Everyone is an adult here, we need to be acting like it. How many times are we going to let Ryan get upset and have to yell? None of it is necessary.
1929 Model A Ford Coupe |
06-24-2013, 06:44 PM | #30 |
Re: Logan
06-24-2013, 07:00 PM | #31 |
Re: Logan
whats wrong jeff are you done pm'ing i am just getting started
06-24-2013, 07:25 PM | #32 |
Administrator
Re: Logan
Jesus god... Some of you fellas need to find another website... Cuz you won't be on this one much longer.
I don't host name calling, drama, crap... Take it elsewhere! |
