Old 02-24-2013, 05:35 PM   #1
GearRat
GearRat's Avatar
Default Oil pan removal?
Trying to figure out how to get the oil pan off of my '35 5 window. Pan is free from engine and trans, but having a hard time getting it off completely. It is getting caught on the the bars running from where the trans is up to the steering knuckles. Engine is hoisted up. Any suggestions?
GearRat is offline   Reply With Quote
Old 02-24-2013, 05:56 PM   #2
G.M.
Default Re: Oil pan removal?
Loosen the wish bone and prop it down 3 or 4 inches. turn the engine so the front counter balance on the crank shaft is down. Be careful it don't fall down and hit you. G.M.
www.fordcollector.com
Old 02-24-2013, 07:35 PM   #3
Willit Stop
Willit Stop's Avatar
Been there....Three times. A little friendly advice though.Make sure you put the right gasket back on.Look for the little vent (if it has one)on the passenger side front. Ask me how I know.
Willit Stop is online now   Reply With Quote
Old 02-24-2013, 08:17 PM   #4
jim1932
jim1932's Avatar
Probably not the same issue, but on my 32 turning the steering wheel allowed the pan to drop
jim1932 is offline   Reply With Quote
Old 02-25-2013, 08:11 AM   #5
31chevy
31chevy's Avatar
Been there, done exactly that.
Gary.
31chevy is offline   Reply With Quote
Old 02-25-2013, 09:27 AM   #6
35 coupe
35 coupe's Avatar
It is probably getting hung up on the oil pump pick-up that goes to the bottom of the sump
35 coupe is offline   Reply With Quote
Old 02-25-2013, 12:01 PM   #7
Willit Stop
Cuss words have to be in the right order.
