Old 07-31-2020, 12:17 PM   #1
modela4shane
Default Pcv valve effect on load o matic
Can a PCV valve have any negative effect on the load o matic distributor on a 8BA. Could the ported vacuum signal to the distribulor be diminished using a PCV connected to the wiper port on the intake? Any thoughts, Thank you.
modela4shane is offline   Reply With Quote
Old 07-31-2020, 12:23 PM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: Pcv valve effect on load o matic
Ran a PCV for a couple of years while using the loadamatic with no issues.
PCV uses manifold vacuum not venturii vacuum.
Does it effect it when you turn your wipers on??
Old 07-31-2020, 03:32 PM   #3
V8COOPMAN
V8COOPMAN's Avatar
51 MERC is correct...PCV systems use MANIFOLD vacuum. DD
Click Links Below __
T5 W/TORQUE TUBE
