Old 12-22-2023, 05:02 PM   #1
Cameron Koehn
Cameron Koehn's Avatar
Default I broke a new ring.
So.. I was installing cast grant rings P.N. P3108.100 and spreading them using a Lisle ring spreader. Everything was fine with four pistons ringed and installed in their bores. Then I started putting rings on the other four pistons. I got several done. As I was spreading one of the oil rings, but just before it fit over the piston, it shattered. Now what. Order a whole new set? Any thoughts or ideas?
Engine is 1952 flathead v8 bored .100 over.
Thanks for looking!
Flathead Flatfender
Cameron Koehn is offline   Reply With Quote
Old 12-22-2023, 05:49 PM   #2
deuce_roadster
deuce_roadster's Avatar
Default Re: I broke a new ring.
Contact Grant with part number and explain, purchase a single oil ring. Maybe install all the rest of the rings on the pistons in case you need to buy more than 1. Maybe they sent you a wrong sized one in the box.
Old 12-22-2023, 06:54 PM   #3
Ronnieroadster
Ronnieroadster's Avatar
If the oil ring you broke is the bottom one located below the wrist pin here's a suggestion. There's no need to run that lower oil ring many engine builders myself included always eliminate that lower ring. The upper oil ring is more than adequate for the correct oil control. Another added bonus when eliminating the lower oil ring is reduced internal friction. If it was me I would simply remove the remaining lower oil rings and now continue on the engine assembly.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline.
First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH
Ronnieroadster is offline   Reply With Quote
Old 12-22-2023, 07:21 PM   #4
Cameron Koehn
I would do that Ronnie, but it is the second oil ring from the bottom and I already have all the other pistons in.
Flathead Flatfender
Old 12-22-2023, 07:30 PM   #5
Jack E/NJ
Jack E/NJ's Avatar
Use one of the old rings that still looks decent.
Jack E/NJ is offline   Reply With Quote
Old 12-22-2023, 08:36 PM   #6
richard crow
jack is right if its the same size when i went to school the teacher said the oil ring never wars out ?
richard crow is offline   Reply With Quote
Old 12-22-2023, 08:40 PM   #7
Ken/Alabama
Ken/Alabama's Avatar
What Ronnie said.
Ken/Alabama is offline   Reply With Quote
Old 12-22-2023, 09:38 PM   #8
Cameron Koehn
Well I can't use one of the old rings because they would be .020 underbore. I broke the ring with the internal spring, so maybe I could just move the bottom ring up to 3rd place and not have a bottom ring?
Flathead Flatfender
Old 12-22-2023, 09:45 PM   #9
cmbrucew
cmbrucew's Avatar
Call Egge Machine next week. They will sell singles.
562 945 3419 They are in Santa Fe Springs, Ca. 90670
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 12-22-2023, 10:14 PM   #10
tubman
tubman's Avatar
While I agree that the bottom oil ring is unnecessary (I have successfully eliminated them from my last two builds), doesn't it cause balance problems? I've never really thought about it, as I always have my rotating assemblies balanced, but wouldn't it cause a dynamic balance problem?
Old 12-22-2023, 11:58 PM   #11
aussie merc
aussie merc's Avatar
old trick by my mechanic when an apprentice [long time ago] he would warm the rings up with a hair dryer before fitting 5 years never saw him have any drama
aussie merc is offline   Reply With Quote
Old 12-23-2023, 09:07 AM   #12
deuce5wndw
deuce5wndw's Avatar
Haven't tried lately but the oil ring companies used to sell rings for one piston but not one single ring.
deuce5wndw is offline   Reply With Quote
Old 12-24-2023, 09:28 PM   #13
Ronnieroadster
Darn I was hoping it was the bottom oil ring. Like Bruce wrote above call Egge next week I'm sure they can help you with a ring. I think there closed until the 27th
Ronnieroadster
Old 12-25-2023, 11:08 AM   #14
Scott52
I did that. I found an incomplete set on Ebay and after I got want I needed I posted up sets for the price of shipping.
Scott52 is offline   Reply With Quote
