Old 11-07-2023, 06:47 PM   #1
rawlir
Default 1947 Ford pickup Rebuild
I am rebuilding a 47 Ford pickup. Should the inner fenders be bolted to outer fenders before bolting to frame or should i bolt inner fenders to truck, then bolt outer fenders to inner fenders & frame? Then place & secure front clip prior to installing the hood?
Thanks.
rawlir is offline   Reply With Quote
Old 11-07-2023, 07:12 PM   #2
pistonbroke
Default Re: 1947 Ford pickup Rebuild
It's been a long time, if my memory bone serves me right we assembled the nose clip on the shop floor starting with the inner fenders loosely bolted to the core support. Then lower pan, fenders and grill panel last. With the radiator in three guys can gently lift the whole assembly onto the truck. I recommend you leave all bolts just snug as once things are on the frame you may need to do some adjusting or fine tuning as some call it. It can get a little compex around the sides of the grill as all three panel come together at this seam. This was all from my memory of 1976 so best of luck, Tim
pistonbroke is offline   Reply With Quote
Old 11-07-2023, 11:21 PM   #3
GB SISSON
GB SISSON's Avatar
Having done this job 5 times in the past ten years, I concur with Tim. If necessary, two guys can lift it on. I installed it once by myself, dangling the clip from an overhead winch line and driving into it, then lowering into place. Pretty much the same as docking the space shuttle. I also remove the front bumper as it's in the way when doing everything else and it goes back on after the fenders/clip is on. Make sure you install and dial in the grille bars while clip is off. So much easier access.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson)
Old 11-09-2023, 10:01 PM   #4
cmbrucew
cmbrucew's Avatar
I remember seeing a post by Mike Kubart describing step by step front assembly for a 39 or 40. He wrote the book.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
