Good tight rebuilt 39 Ford trans in a 48-case. Standard gear set with 28 tooth cluster. All parts hot tank washed and inspected. Minimal wear and no chips. Second gear thrust clearance is .004 versus Ford spec of .004 - .007. Cluster thrust clearance is .008 versus spec of .004 - .017. New bearings, brass synchros and seal. Double detent shift top with correct 91A second gear fork.
Shipping in CONUS is $100.
For information e-mail me at
[email protected] or call me at 319-377-8795. The latter is a land line and I don't do texts. Pickup in Cedar Rapids, Iowa is preferred.
