11-11-2018, 08:41 AM | #1 |
8ba camshaft I.D.
I have a never been run camshaft with the markings stamped on the end C8RT? It appears to be a regrind. Need help identifying it. Thanks John
11-11-2018, 10:56 AM | #2 |
Re: 8ba camshaft I.D.
I suspect it's a Canadian 49-51 Mercury (Ford) truck camshaft. 8RT is a truck marking.
11-11-2018, 11:51 AM | #3 |
I concur. And, IF it's a re-grind as you suspect. the only way to determine what it actually is is to degree it.
11-11-2018, 12:26 PM | #4 |
Yes, it would be interesting to know what the new "grind" is all about.
Can you check it out? Is there an easy way to check it (on the workbench) with a dial indicator or micrometer? I would like to check one out also. |
11-11-2018, 12:32 PM | #5 |
All you can do on a bench is measure the lobe life with calipers or a micrometer. To check duration and open/close events you would have to do it in the block and use a degree wheel.
Sal |
11-11-2018, 01:01 PM | #6 |
11-13-2018, 08:58 AM | #7 |
I will check the lift and let you know. Thanks
11-13-2018, 09:01 AM | #8 |
Just check base circle diameter, that will be a good indication if it has been reground
11-18-2018, 08:27 AM | #9 |
I checked the lift and it is .397
11-18-2018, 09:30 PM | #10 |
Definetely reground.
