06-20-2011, 06:30 PM | #1 |
Valve Seat Grinder
Me being an old tool nut I just bought a Hall valve seat grinder with pilots & stones included. I was able to download a parts list with a brief summary on how to xcare for it. Does anyone have a real users manual that can be copied? It also included what appears to be a flexible cable attachment kind of like a dremel tool which seems to allow grinding seats from an angle. Any info will be appreciated.
Thanks, Tony G. |
06-20-2011, 08:21 PM | #2 |
Re: Valve Seat Grinder
I use a Neway valve seat cutting tool. It machines both angles on the seats.
06-20-2011, 09:41 PM | #3 |
The Hall toledo is one of the best valve seat grinders (my opinion), it works different than all the others, it has an eccentric bushing and the stone only touches a small area, the stone turning fast, the eccentric turning slow,it goes around and around, there is a knob on top to control the depth of cut.
I have a lot of documation on B&D, and Sioux, but I don't think I have any on the hall and I wouldn,t be able to look till the weekend. I did find it online-- http://www.hall-toledo.com/index_files/Page400.htm Do you have the special pilots for "A" and V8, the pilots that fit in place of the valve guide? I have B&D, Sioux, neway, and the Hall ---it makes the nicest seats,but is slower that Sioux, and B&D, |
06-21-2011, 03:51 AM | #4 |
Hi Kurt,
Thanks for the info. Sorry to say I dont have the Ford pilots. I have the B&D pilots for the A & B Fords in my regular valve setup.Too bad I'd like to use this Hall in my next motor project. |
06-21-2011, 08:45 AM | #5 |
They do show up on E-bay from time to time, I think only the hall pilots have the straight groove.
06-21-2011, 12:52 PM | #6 |
06-21-2011, 02:36 PM | #7 |
I have a Hall-Toledo eccentric, great machine, it uses taper arbors with a collect
affair at the bottom and a nut at the top. I also have a Kwik-way with a long extension on it, both electric and air, ( can't lift the electric anymore ) and if I remember correctly we used it to do seats on the Offy's |
06-21-2011, 04:44 PM | #8 |
The swivel handle on top has what looks like number increments on a micrometer, does the handle screw in and out or is it just for a hand hold ?
06-21-2011, 04:55 PM | #9 |
Tony,
Post a photo(s) of you grinder if you can. I'm not sure what a " swivel handle " is. Dudley |
06-21-2011, 06:28 PM | #10 |
The micrometer type swivel handle device on mine is a counterbalance spring to compensate for it's weight when it is used on a V type engine in the chassis --look in the link in my other post, the instructions are in there on the company website ---I think they still sell parts.
03-18-2015, 07:06 PM | #11 |
I just started a Yahoo Group for the Hall-Toledo Model EJ Eccentric Valve Seat Grinder. I have 7 PDF type manuals for this machine that I took the time to scrub and clean to make them like new more important readable. These manuals go back as far as the 1940's and a few from the mid to late 1950's and some from the 1980's. I also found some wire tag type cards that were more than likely fastened to it when it was new, those have been scanned to a PDF format as well. These documents are provided free of charge.
Regards, Jack groups.yahoo.com/neo/groups/hall-toledo_groupurl/info Last edited by jaksm1; 03-19-2015 at 05:27 PM. |
