Old 08-16-2019, 01:19 PM   #1
rer_239
rer_239's Avatar
Default Anyone use a TomTom gps?
Anyone use one & it's so, how do u convert it to 6 volt? I don't want to use my phone cause it'll eat up my minutes
Thanks
Dick
rer_239 is offline   Reply With Quote
Old 08-16-2019, 01:48 PM   #2
Curtis in MA
Default Re: Anyone use a TomTom gps?
There is another thread on GPS charging. Last updated this morning.
Says that the regulator is in the plug.
I use my phone and GPS on 6volts.
Curtis in MA is offline   Reply With Quote
Old 08-16-2019, 01:56 PM   #3
160B
160B's Avatar
I use a Garmin navigator and have a small 12 volt battery 9Ah Rechargeable Sealed Lead Acid AGM Battery under the front seat. I connect to the battery with a Car Accessory female Cigarette Lighter Socket cord that lies on the seat. I connect to the battery using a Car Accessory male Cigarette Lighter plug. And I charge the battery using a Car Accessory male Cigarette Lighter plug.
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 08-16-2019, 06:17 PM   #4
Davew
Davew's Avatar
I have a garmin and use a small cell phone/tablet charger. Works great. Rechargeable.
https://www.amazon.com/Anker-PowerCore
Davew is offline   Reply With Quote
Old 08-16-2019, 07:18 PM   #5
California Travieso
Send a message via Yahoo to California Travieso
I use a Garmin as well, but I don't use the female Cigarette Lighter Socket. My Garmin comes with USB cord that was intended to download software updates but can be used to also charge. Just plug it into to USB port of any independent charger.
David Serrano
California Travieso is offline   Reply With Quote
Old 08-16-2019, 07:32 PM   #6
CarlG
CarlG's Avatar
David Serrano
I hardwired a USB port in my pickup and plug my Garmin Nuvi into that. I have that port switched so it comes on automatically when I turn on my ignition.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 08-16-2019, 07:47 PM   #7
wmws
I don’t know about Tom Toms but Germans run on 5 volts. The adapter will cut the volts down from 12 or 6 down to 5. Assuming you have a standard Model A with positive ground you have to be careful about the polarity. Reverse the wires + to - and - to +. If your adapter case has metal around it be careful because now it is hot and will short to ground. Just insulate it somehow with tape or something non conductive.
wmws is offline   Reply With Quote
Old 08-16-2019, 09:29 PM   #8
California Travieso
That's a better idea, Carl. I'll have to try that.
David Serrano
Old 08-17-2019, 07:22 AM   #9
chap52
chap52's Avatar
With 6 volts positive ground...Remember polarity when hooking up a plug... Chap
Old 08-17-2019, 08:11 AM   #10
Merc Cruzer
Merc Cruzer's Avatar
This might provide a solution:
https://www.fordbarn.com/forum/showt...ing+cell+phone
Merc Cruzer is offline   Reply With Quote
Old 08-17-2019, 11:02 PM   #11
PalAl
PalAl's Avatar
If I did this right you should have an attachment. I did this and it works great for my GPS/Cell Phone
File Type: pdf Cell Phone Power in a 6-volt Model A.pdf (724.2 KB, 56 views)
PalAl is offline   Reply With Quote
Old 08-18-2019, 04:11 AM   #12
Wick
Wick's Avatar
Put the Waze app on your phone. This will do everything, speed,traffic, places of interest.
GPS devices are a thing of the past.
Wick is offline   Reply With Quote
Old 08-18-2019, 04:49 AM   #13
johnbuckley
johnbuckley's Avatar
Does Waze always work out of phone range? I can nearly always get a GPS signal , but using a phone app is uncertain in some patches because of areas of poor phone coverage
Old 08-18-2019, 09:54 AM   #14
Merc Cruzer
I don't mean to hijack the thread but does anyone make one of these units that will jump/charge 6 volt and 12 volt cars?
Old 08-18-2019, 10:08 AM   #15
160B
160B's Avatar
FWIW
The Model A Ford is a thing of the past!!
Old 08-19-2019, 07:55 AM   #16
Forddan
I did a google search to check if I can use my phone GPS app out of the provider coverage area and it came that, Yes I can.
This is for Android :
http://backcountrynavigator.com/android-gps/
Cheers
Forddan is offline   Reply With Quote
Old 08-19-2019, 08:29 AM   #17
jhowes
I'd like to know how people connect devices to the ignition switch to turn it on and off. The ignition switch only connects the coil to the points and does not provide a way of turning on or off anything. Jack
jhowes is offline   Reply With Quote
Old 08-20-2019, 09:33 AM   #18
30 Closed Cab PU
Tap into the ignition switch existing wiring, or some venders offer an ignition switch with a spare wiring contact/connection.
