03-03-2021, 04:33 PM | #1 |
how to measure crankshaft end play
we have 1950 8BA in a 47 ford car , is there a way to get a close end play measurement 0f the crankshaft ? One shop told me .006 another said .014
my head hurts , thx tom |
03-03-2021, 04:38 PM | #2 |
Re: how to measure crankshaft end play
on old loose motors you can usually just push the flywheel in and out by hand, or with a pry bar. set up a dial indicator and see the readings when you move it. if no indicator i imagine you could set up something to measure off and do it with feeler gauges
03-03-2021, 04:42 PM | #3 | |
cas3 has much of it. Generally the how, uses a dial indicator placed at one end of the crank while shoving said crank back and forth in a sensible manner frequently with prying tools. The how much answer I don't have for your application. Let's see who chimes in.
-Jeff H Have you thought about supporting the Early Ford V-8 Foundation Museum? Last edited by VeryTangled; 03-03-2021 at 04:49 PM. |
03-03-2021, 06:42 PM | #4 |
According to the Motors Repair Manual the crankshaft endplay for the 1952-53 V-8 239 cu. in engine is .004 to .008 in. I would think 1950 engine would be the same.
03-03-2021, 07:05 PM | #5 | |
I had a chevy 350 tat the end play must hafe been 1/4 inch
If it would have been a snake it would have bit ya! i can't spell my way out of a paper bag! |
03-04-2021, 08:18 AM | #6 |
The technique of infamy is to start two lies at once and get people arguing heatedly over which is true. ~ Ezra Pound |
03-04-2021, 09:20 AM | #7 |
I try to stay within the spec . . . otherwise either the thrust surfaces of the rear main bearings are worn, or the crank thrust surfaces . . . or both.
