02-10-2014, 11:58 AM | #1 |
radio noise supppression
I have been thinking of attaching wiring to the speaker of a little transistor
radio I have and attach these wires in turn to a speaker behind the header of my 36 ford. I would put the radio in the glove compartment. My question is, will radio noise still factor in or does this just happen when the radio is part of the car's electrical system? Would I have to insulate the speaker from the metal header above the windshield? |
02-10-2014, 01:52 PM | #2 |
Re: radio noise supppression
I'm afraid that your question may not be able to be answered definitively without just trying what you propose. I've been doing essentially the same thing in my car for years and never had static as long as I used a portable CD player for my source of sound but as soon as I switched to an MP3 player I had uncontrollable static. http://www.fordbarn.com/forum/showthread.php?t=124782
The other thought I had is that the earphone jack/speaker output on your portable radio may not put out enough power to run your speaker at an acceptable level and you may need to boost the signal a bit with a headphone amplifier. If you decide to try that shop for mili-watt output to get the highest you can get. The are not all created equal.
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
02-11-2014, 01:52 PM | #3 |
