Old 03-05-2013, 10:12 PM   #21
Tinker
Tinker's Avatar
Default Re: New to Y-block, Intake Manifold Puzzle
Ill just call it, nice. Get a couple of y block books and read through them. Best i can suggest.
Old 03-05-2013, 10:30 PM   #22
Dobie Gillis
Dobie Gillis's Avatar
Will do.
Dobie Gillis is offline   Reply With Quote
Old 03-05-2013, 10:35 PM   #23
Tinker
Tinker's Avatar
Not sure the length but pull one of the front bolts and match up the threads and size. I wouldnt put a bolt in the threads more then a half inch. Threads are in the head, not the intake. Or pick up a bolt set for the right intake you have, probably 10 bucks.
Old 03-06-2013, 09:31 AM   #24
GREENBIRD56
GREENBIRD56's Avatar
I'll stick in two cents here, quick like - be certain you don't put too long a capscrew into the head from that position. It is lined up to interfere with the nearby pushrod and can (and will) cause more trouble than you bargained for.......
GREENBIRD56 is offline   Reply With Quote
Old 03-06-2013, 10:08 PM   #25
Dobie Gillis
Not to worry. I gotta pull the intake to change out the leaky valley cover gasket so I'll be able to measure how much capscrew I need at the same time.
