Old 03-17-2021, 06:43 PM   #1
my2nd40
my2nd40's Avatar
Default Flathead Adjustable Lifter question
Some folks grind down the top of the lifter bore to aid in getting a wrench on the lifter bolt to make the adjustment. How much is too much to grind off. I've seen some pictures of engines in some books that the lifter bore looked to be ground down a 1/4" or even more. Won't that affect how the lifter might ride in the bore?
my2nd40 is offline   Reply With Quote
Old 03-17-2021, 07:09 PM   #2
leon bee
Default Re: Flathead Adjustable Lifter question
I just now an hour ago drilled my 16 little holes in a block for that. I'm no expert, but I have done the holes twice before and it all works great. I'll be curious what others say, but I'd rather get in there with a long drill than a grinder.
leon bee is offline   Reply With Quote
Old 03-17-2021, 07:11 PM   #3
leon bee
Maybe I misunderstood. But I haven't had any trouble getting a thin wrench on the adjuster bolt.
Old 03-17-2021, 08:10 PM   #4
alanwoodieman
drill the hole as low as you can, especially if you have a regrind cam. a lot easier to drill the hole than to grind down the top of the lifter bores
Old 03-17-2021, 08:13 PM   #5
JSeery
JSeery's Avatar
This all depends on the cam base circle. With the higher lift cams the you have a smaller base circle and the adjuster head is lower in the bore.
Old 03-17-2021, 08:22 PM   #6
19Fordy
19Fordy's Avatar
Drilling the holes is a lot better method than grinding. Don't even consider grinding.
Old 03-17-2021, 08:27 PM   #7
leon bee
This is what I realized he may be talking about.
Old 03-17-2021, 09:29 PM   #8
Bored&Stroked
Bored&Stroked's Avatar
He's not talking about the holes that are used to insert a punch/rod to stop the lifter from turning, he's talking about the fact that with a high-lift cam (which means small base circle), the adjusting nut is not up high enough to get a wrench above the lifter boss to adjust the lifter. This makes it a REAL pain in the butt in that you now have to turn the crank to get the lifter up, adjust it with a guess, then turn the crank to get it on the back of the cam again . . . then measure and keep repeating this until you get it right. This can add HOURS to the job - and lots of chances to get it wrong.
If you grind the top of the lifter boss down a bit, then you can get your wrench in there.
So, to answer the original poster's question, the amount you need to grind is strictly dependent upon your block, your cam and your lifters. I would put the cam, and two lifters, two valves (one intake, one exhaust) and see how far down the adjuster is. Then you'll now how much to grind the lifter boss.
You need to go the right depth and then wide enough to be able to turn the wrench.
Also, grind the heck out of a 7/16 quality wrench to make it your special "tappet wrench". Make it about 1/8" thick and grind the sides to give you more turning radius in the lifter bore area.
On an engine that I'm currently building with a Potvin 3/8 cam (.375 lift), it takes about a 3/16 grind on the lifter bore - the width of the boss, to make it easy to adjust the lifters.
Once you've done, you should deburr the edges.
Also, you have to thoroughly clean the engine afterwards. This includes removing the cam bearings and doing a complete soap/wash, rifle brush, etc.. The last thing you need is the cast iron filings laying around somewhere in the block - just waiting to be picked up in oil so they can wipe out your bearings.
I usually do ALL the above work - before I bring the block to the machine shop for all the boring, valve, etc.. work.
Good luck!
Old 03-17-2021, 10:58 PM   #9
Ol' Ron
Ol' Ron's Avatar
I use a small piloted shell mill to re move about .075/.100" off the top of the lifter bore. Makes life much easier.
Gramps
Old 03-18-2021, 07:02 AM   #10
Bored&Stroked
I use carbide rotary files to do my relieving of the top of the lifter bores. Then I follow up with sand-paper rolls to smooth things out and remove any sharp edges. It takes an hour or two to do this work - bit it is well worth it if you are running adjustable lifters with a small base-circle cam.
Old 03-18-2021, 08:32 AM   #11
51 MERC-CT
51 MERC-CT's Avatar
Yep' nuthin' fancy.
Old 03-18-2021, 08:43 AM   #12
marko39
How long are the drill bits required to drill the lifter bores?
marko39 is online now   Reply With Quote
Old 03-18-2021, 08:54 AM   #13
51 MERC-CT
51 MERC-CT's Avatar
Standard length with appropriate drill motor.
Old 03-18-2021, 09:21 AM   #14
JSeery
JSeery's Avatar
I use extended bits that allow more clearance for the drill motor. I have some 12 inches long and some around 18 inches long.
Old 03-18-2021, 09:46 AM   #15
Grease348
Grease348's Avatar
I’ve got a question about the 1/8” hole I the lifter bore. Inserting a Allen wrench to hold the lifter does that work on the newer type lifter that isn’t hollow but has shallow depressions?
Grease348 is offline   Reply With Quote
Old 03-18-2021, 09:55 AM   #16
19Fordy
19Fordy's Avatar
Bored & Stroked, Thanks for the feedback and clarification on my misunderstanding the "drilling hole" problem.
Old 03-18-2021, 11:57 AM   #17
Ronnieroadster
Ronnieroadster's Avatar
To answer your question the 1/4 inch example may sound excessive causing a loss of lifter stability but it really has no ill effect. There's almost no side loading of the flathead Ford lifter.
As an example of how the lifter bore design is more than adequate for the example above. There's a far more extreme lifter application used on the flathead when you put a set of ARDUN overhead valve heads on the flathead block. The liters required for the ARDUN conversion as close to twice the length of the flathead lifter. This additional length is required so the push rod can pass threw the original guide holes to actuate the rockers. This taller lifter increase side loading substantially due to this push rod angle location.
My experience after many thousands of miles with this additional lifter side loading has shown no additional lifter bore wear. This is of course an extreme example of possible lifter bore wear but as I wrote the bores handles all of it perfectly.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline.
First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH
Old 03-18-2021, 12:49 PM   #18
flatjack9
flatjack9's Avatar
Yes it will
Old 03-18-2021, 07:34 PM   #19
FRANK PKNY
FRANK PKNY's Avatar
I drill the holes and use a tappet wrench. All us old guys have tappet wrenches.
FRANK PKNY is offline   Reply With Quote
Old 03-18-2021, 08:02 PM   #20
Bored&Stroked
Hey no problem - just trying to help out and hope you didn't take it as a "poke" at you. Was trying to leave in a hurry and didn't quite lead into my dissertation in a fluid manner! Hope you didn't take it as a step on your toes - it was not meant to be.
