05-22-2023, 03:27 PM | #1 |
Early Lever Shocks
Several years ago I purchased some new A/32 style lever shocks. Was the company Sipes? Can't seem to find any information. Thanks
05-22-2023, 03:35 PM | #2 |
Re: Early Lever Shocks
05-22-2023, 04:17 PM | #3 |
Thanks
05-24-2023, 07:55 AM | #4 |
I believe that A and 32 shocks are not exactly the same . . . just wanted to throw that out there.
05-24-2023, 08:16 AM | #5 |
I found his ad on the net. He advertises them as A/32?
05-24-2023, 08:22 AM | #6 |
05-24-2023, 09:10 AM | #7 |
Bolt arrangement is little different. That's why original ´32 front shocks are so expensive at swap meets.
05-24-2023, 10:04 AM | #8 |
Actually, it is the height or width of the shock absorbers that differs. Both the early manually-adjustable and the thermostatically-controlled (self-adjusting) '32 shocks are 1/4" taller, back to front than a Model A shock. The attachment hole pattern is the same. The back of a '32 shock has a spoke pattern to the casting while the back of a Model A shock is basically flat.
The reproduction A shocks will work on a '32 as noted above. The shock links will end up at a slight angle with stock '32 shock arms because of the narrower width of the A shock, but not enough to compromise their functionality. |
