07-30-2016, 01:01 PM | #1 |
I D Banjo Steering Wheel
Can anyone ID This banjo steering Wheel. I was told 39. If so is there any other years that the horn button will work?This will be a nice wheel after doing a little repair and paint.
07-30-2016, 01:29 PM | #2 | |
Re: I D Banjo Steering Wheel
http://www.fordbarn.com/forum/showthread.php?t=158116 Last edited by V8COOPMAN; 07-30-2016 at 01:35 PM. |
07-30-2016, 02:33 PM | #3 |
The 37-39 wheels are similar,they used a light switch and horn button, attached to a rod.What's your application?
07-30-2016, 04:16 PM | #4 |
38 and 39 the spokes spread wider at the hub.37 hub different for the horn button.37 is all alone.Barnnone's wheel is a 37.
07-30-2016, 04:31 PM | #5 |
I have another question does the slug style have any consideration . On mine you will see 1 hole on the back not 3 like the pic that DD posted.
I have a 39 drop that I would like to use. I believe I need a 39 steering mask is that correct or can I use something else? I have a 31 sedan with a flathead motor and would like to use cross Steer box. Thanks all for your help. |
07-30-2016, 05:04 PM | #6 |
07-30-2016, 05:13 PM | #7 |
I believe he's speaking of the three pieces that sit half-way on the three sets of spokes. If you look at the rear side of his wheel, EACH piece appears to have one hole in it's center. Looking very closely at the wheel I posted, those three thingies EACH appear to have THREE holes, compared to his ONE hole. DD
07-30-2016, 07:39 PM | #8 |
Thanks DD.That could be made from a different vendor.
07-31-2016, 10:20 AM | #9 |
Thanks for the help for the ID of my banjo Wheel. Depending if I can find a good steering box with the correct Mast or try what deuce lover said using a exhaust tube and make my own. prefer using Ford parts when possible.Still have a lot to do before the steering box is a issue.
07-31-2016, 11:29 AM | #10 | |
07-31-2016, 01:35 PM | #11 |
Great I will PM you .. Thanks George
