Old 03-05-2018, 10:02 AM   #1
31Abone
31Abone's Avatar
Default 32 ford pu beep horn photo
lookin fir 32 beep horn photo,i have motor type and want a sparton cf type but need good pictures ..thanks
31Abone is offline   Reply With Quote
Old 03-05-2018, 10:27 AM   #2
DavidG
DavidG's Avatar
Default Re: 32 ford pu beep horn photo
These should help. The bracket on the right in the bracket photo is the correct one for CF horn.
Old 03-05-2018, 12:30 PM   #3
BoxCar Tom
BoxCar Tom's Avatar
Dave, I have a beep horn with a slightly different bracket. The bracket has a curve that conforms to the curve of the horn rather that the horse shoe shape of the bracket in your picture. Is the horse shoe bracket a hard and fast rule? Thanks,
BoxCar Tom is offline   Reply With Quote
Old 03-05-2018, 12:57 PM   #4
BoxCar Tom
BoxCar Tom's Avatar
I have these other brackets that I could use to make a conforming CF bracket. Before I do that I'm wondering what they are for? Anybody know?
Old 03-05-2018, 01:19 PM   #5
31Abone
31Abone's Avatar
Mr davy I have some photos of cf horn on original cars but they don't look like your photo info ..are they wrong ?may have been changed somewhere along the track ?..sc but i think you are correct on this.
Old 03-05-2018, 02:02 PM   #6
DavidG
DavidG's Avatar
The four pieces of thin spring steel that form the upper portion of the vibrator horn bracket are seen both ways and I for one wouldn't worry about the difference.
Old 03-05-2018, 03:43 PM   #7
Andy
I have a beep horn on my 3W and it mounts with the tall bracket with the springs. I also have a beep horn that mounted under the light bar. Is it 32 truck or maybe 33-34 truck? Thanks
Andy is offline   Reply With Quote
Old 03-05-2018, 07:29 PM   #8
DavidG
DavidG's Avatar
All of the '32 horns mount on the left front fender flange, whether LHD or RHD. Those that mount under the headlamp bar are for '33-'34 commercial vehicles/trucks although the only difference is the mounting bracket.
Old 03-06-2018, 12:20 AM   #9
rbullockv8
rbullockv8's Avatar
Here are pics of the horn on my August '32 Roadster PU. This bracket it curved, not U-shape, where it attaches to the horn body. Now, if I could just get it to beep like it's supposed to.
1932 Model B Roadster Pickup
rbullockv8 is offline   Reply With Quote
Old 03-07-2018, 12:28 AM   #10
uncle buck
uncle buck's Avatar
Is the bracket available anywhere in reproduction?
uncle buck is offline   Reply With Quote
Old 03-07-2018, 06:24 AM   #11
DavidG
DavidG's Avatar
Not that I'm aware of; only the early version shown on the left side in my photo above has been reproduced.
Old 03-08-2018, 07:38 PM   #12
cas3
while we're on the subject, what do i have here, 32-3 or 4 ?
Old 03-08-2018, 07:52 PM   #13
DavidG
DavidG's Avatar
'33 or '34. although the bracket might be a modified '32 version; same horn, in any event.
Old 03-08-2018, 07:56 PM   #14
cas3
thank you very much!
