Old 10-29-2020, 04:14 PM   #1
tquigley
Default Best practice in removing '54 F100 doors
I am restoring a '54 F100. Looked at door hinges and access to the pillar 6 bolts or the access door on the door itself (6 bolts). It seems that the door bolts make an easier removal. Any advice out there? Thanks.
tquigley is offline   Reply With Quote
Old 10-29-2020, 04:19 PM   #2
ahshoe
Default Re: Best practice in removing '54 F100 doors
Did the door bolts on my project. Makes it so much easier to reinstall too.
ahshoe is offline   Reply With Quote
Old 10-29-2020, 07:26 PM   #3
paul2748
paul2748's Avatar
If the doors fit good now, take some pics of the bolt locations on the door for easier reassembly.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 10-29-2020, 07:55 PM   #4
dmsfrr
dmsfrr's Avatar
If you drill an 1/8th inch hole thru the door side of each hinge into the door before disassembly, you can use them to index the door into the original position when reassembling.
Old 10-30-2020, 02:57 PM   #5
frank long island
frank long island's Avatar
i second the drilling of holes take the doors off first if you need to remove from the body do the same i do this all the time on a side note eastwood has a kit for this its amazing how much new weather striping or being off on a setting will ruin your day ,i speak from doing i was working on a 51 f 1 floors/rockers were welded not by me without doors on truck had to shave weather striping twist the door frames [not fun] but got them to close with 1 finger and seal tight
frank long island is offline   Reply With Quote
