Old 02-20-2021, 10:19 AM   #1
1948F-1Pickup
1948F-1Pickup's Avatar
Default Clutch chatter eliminated finally
I removed the pedal carrier/support the other day to replace the bushings that the brake and clutch pedal rotate on.
I discovered that the rear portion of the clutch linkage rod was "wallowed" out.
(It's pretty much buried in there when everything is assembled and hard to see)
It's part 7RT-7521 and the damage looked similar to the first photo.... roughly double the hole size that should have been there.
Welded that mess up and re-drilled to something closer to the second photo.
Nice to be able to release the clutch now and not shake the truck to pieces.
1948F-1Pickup is offline   Reply With Quote
Old 02-20-2021, 12:19 PM   #2
Ross F-1
Ross F-1's Avatar
Default Re: Clutch chatter eliminated finally
Mine was about the same, so I replaced it. I was also having clutch chatter but it didn't really help. Just having a fresh piece in there, with grease on it, did make the clutch action much smoother.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 02-20-2021, 12:24 PM   #3
19Fordy
19Fordy's Avatar
Well done. Great detective work.
Old 02-20-2021, 12:56 PM   #4
Kube
Kube's Avatar
Many, MANY guys never address all the wear points in the linkages required to shift properly.
The bushings that surround the clutch release shaft, the shaft itself, the shaft and bushings at the pedal bracket, the rod (as you'd depicted) and the pin. All of these wear points add up exponentially and as such make shifting difficult if not impossible at times.
Old 02-20-2021, 01:52 PM   #5
1948F-1Pickup
Thanks. Prior to this discovery I had convinced myself that I needed a
disc with decent friction on it and a better pressure plate.....
Old 02-20-2021, 01:54 PM   #6
1948F-1Pickup
I really, really did not expect that removing the play at that "rod" end would contribute to that significant of an improvement....
Old 02-20-2021, 02:17 PM   #7
Kube
Kube's Avatar
Rest assured you are not alone. I have repaired numerous cars for folks that turned out required bushings, etc. All too often this was after they had replaced the clutch assembly. Kind of added salt to the wound when i had to remove the transmission, etc.
Old 02-21-2021, 01:41 PM   #8
slowforty
slowforty's Avatar
I had a 40 with a horizonal crack in the clutch equalizer shaft. When you sat for awhile with the clutch pedal pressed to the floor the clutch would start to engage by itself. Took a little while to figure it out but then again I am slow sometimes(?)
slowforty is offline   Reply With Quote
Old 02-21-2021, 01:59 PM   #9
19Fordy
19Fordy's Avatar
Wow, slowforty, a crack like that sure seems very unusual. Amazed that you found it. Wish you could post a photo of it.
Old 02-22-2021, 12:14 AM   #10
slowforty
slowforty's Avatar
Yeah the part is in the garage and it is too cold to go out.
There was a lot of grease on it so it was hard to find, also changed all the bushings too.
New mounts and good steady rods help a lot.
